603,335 active members*
3,690 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Adjusting backlash on a VK 45 II
Results 1 to 5 of 5
    Hello,
    How do I adjust the backlash on VK 45 2 with seicos M3 controller? I noticed that the Y axis has 0.06 mm backlash. The manuals I have don't show the procedure or how to interpret the mechanical compensation parameters.
    Dec 2009
    559
    Re: Adjusting backlash on a VK 45 II
    Quote Originally Posted by viorel23cnc View Post
    Hello,
    Hello!
    It’s parameter 1833 for the backlash compensation on a Seicos MIII, goes in order of x,y,z
    John
    Jun 2022
    7
    Quote Originally Posted by shas595 View Post
    Hello!
    John
    Please can you describe the procedure?
    Mar 2009
    1992
    did you check if it's possible to eliminate mechanically ?
    Jun 2022
    7
    Quote Originally Posted by Algirdas View Post
    Yes but I have only 0,015mm and for this I think that the software corrections it's okay
  1. Adjusting preload/backlash in these screw support bearings?
    By jevs in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2014, 02:03 AM
  2. Adjusting Y axis backlash Boss 6.1
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2008, 07:31 PM
  3. Adjusting Backlash Compensation on a Cen. 6
    By TZ250 in forum Milltronics
    Last Post: 11-10-2007, 03:31 AM
  4. Adjusting crossfeed backlash on Busy Bee
    By chardinej in forum Mini Lathe
    Last Post: 08-30-2007, 03:15 AM
  5. Adjusting backlash on VF-OE
    By eddie in forum Haas Mills
    Last Post: 12-22-2004, 09:20 AM
