587,693 active members*
3,558 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC router build to machine wood and aluminium (1mX1mX0.4m)
Page 1 of 8 123
Results 1 to 20 of 168
    Sep 2020
    81
    Hi folks,
    I am a newbie in CNC stuff. I have started desginign a CNC router out of my need. I am a hobbyist and I own a small lathe, A drill press, Spot welder, sheet rolling machine, dremel etc. Its a small hobby workshop that I have built out of passion. I use to mill small stuff occasionally on my lathe using a milling attachment. But this is painful and also very limited to what I can mill on it. So finally decided to go CNC router route.
    Commercially available router are very costly for my requirement. for the last 1 week I read about CNC router on this forum and have come up with a design. I appreciate everyones input here to direct me and help me avoid any pitfall.
    Objective: Mostly light aluminium work and some wood carving for RC aeroplane work.
    I first studied some CNC routers and came up with my design. This is like 3rd iteration and I expect it to change here and there. As I will be milling aluminium, I tried making it rigid by having dual linear shaft rod on both side of X axis with four mounting support to avoid any twist/moment.
    Most of the parts are aluminium/aluminum either flat rectangle or extrusion. I have depicted the proposed dimensions on the rough sketch (Little old school).
    Estimated rough weight of the load on each axis: (I calculated it based on metal and part weights)
    Gantry: 32Kg (All vertical load like. Y+Z+vertical support plate)
    X axis: 18Kg (bed+lead screw)
    Y axis: 16Kg (load of Z axis component and its own weight)
    Z axis: 6Kg (including router)
    Below is my spec. I have tried to get what I can get in my country and within my budget. My req. is hobby purpose so it won't be running 5 hours a day.
    3 Nema 23 = (26kg-cm)(368 oz-in) holding torque
    3 DM542 driver
    1 Power supply 40V, 7.4Amp
    Mach 3 breakout board
    Router makita 700W (1HP, I know this is low for aluminium but I could not find any other powerful router here, spindle with VFD are very costly like 4 times)
    Ball screw= Two option available 20X5 or 16X16(this is relatively cheap) I was looking for 16by5 but its not available here.
    Guide linear shaft =16mm on X and Y and 12 mm for Z axis
    Router dimension:
    X end-to-end =1meter
    Y end-to-end =1meter
    Z end-to-end = 0.4meter
    I will work on CAD after I finalize the drawing to get all the parts right and fit well. I have no access to big mill and due to Covid shops are shut mostly. So I will do it all by hand with whatever I have. Could you please help me if I am going right.
    I have not purchased anything yet. I am sizing all parts and cost for it. This whole setup translate to 1200 USD so far. It could have been cheaper but china is not shipping to India. So I am buying locally which is little costlier but quality is certain.
    Open to hear from you guys.
    15362
    Re: CNC router build to machine wood and aluminium (1mX1mX0.4m)
    Quote Originally Posted by Tony_Stark View Post
    Hi folks,
    3 DM542 driver
    Router dimension:
    You are past the magic number, you will need ( 2 ) Ballscrews for the Y or X axis what ever you are calling it ( 1 ) each side or you will get racking and jamming of that axis 20 x 10 Ballscrew is best for the X and Y axis 16x5 for the Z is ok
    Mactec54
    Sep 2020
    81
    Hi Mactec54,
    Two ball-screw will make things costlier. As this means one extra ball screw & one more motor as slave.
    I need to redesign this I guess. I am thinking, what if I replace the 2 linear guide shaft rod on each side of X axis with single 20mm linear guide rail slide arrangement each side. Will that help having single ball-screw arrangement as shown above? Or this issue might still persist as the Y axis is long?
    15362
    Hi Mactec54,
    1 meter is to long for a single central Ballscrew, around 1/2 a meter is all you can get away with in both directions X and Y, it would not matter if you changed the linear rails the same problem happens , the Gantry has to be extremely well designed / built as well so that no flex can happen
    Fixed Gantry with a moving table you can use ( 1 ) central Ballscrew but this design is not for everyone
    Mactec54
    Sep 2020
    81
    I switched to 2 ball screw design as you suggested.
    Sep 2020
    81
    I have started the designing process. I am using single rail on each side of X axis with 20mm ball screw. What could be the best arrangement here. Does this look ok?
    15362
    Looks fine some more details to do for the Ballscrew mounting but the general idea is fine the Ballscrew can be below the rail also, so what ever works best for the rest of your design
    Mactec54
    Dec 2003
    1236
    I strongly suggest that before going too far with a 0.4 metre Z axis that you should draw an accurate diagram of the spindle and collet.Then draw a line from the tip of the tool to the corner of the spindle body,it will allow you to see how you may be limited in terms of places you can get the machine into.If it doesn't look too bad you can progress to adding the spindle backplate and repeating the exercise with the tool tip and the corners of the backplate.You may find that the desire for a big Z axis movement will create a machine that only has limited possibilities for using all the travel.
    Sep 2020
    81
    I totally agree. Having such a long Z axis is not desirable. I will not be able to use all the travel. I have reduced it to 0.2meter.
    Sep 2020
    81
    I have now made my mind on 2 stepper motor for X axis as suggested. Also while I am designing the router in CAD, I have started hunting for the parts. electronics first as rails/guides/ball screws length might change here and there in CAD.
    I have got a good deal on Nema 23 motors with 426 oz-in holding torque. It was little costlier than 368 oz-in one but i liked the built and feel of it when I saw it. So bought 4 of them now. The driver are DM542, four of them. I was looking for a power supply for it as I have 4 motors now to run and 4 drivers.
    Here is how I have calculated the power supply required, please let me know if I am thinking it right.
    Stepper Motor: It has 2.8mH inductance and current rated at 4 Amp.
    Vmax= 32* Sqrt (2.8)= 53.5 volts
    Current= 4 (amps)* 4 (motors) * (2/3) = 10.6Amps
    Drivers: Drivers are rated at 20V-50V DC.
    Now I have two option, Either I go with 48Volt, 10Amp unregulated supply or 36volts 10 Amp.
    48Volts will give out the max speed to motor but its close to driver max range. Shall I settle for 36Volts 10Amp power supply thereby safe guarding the drivers?
    May 2004
    210
    Hi, Tony. I didn't see that you decided on a controller yet - you might consider 32-bit GRBL. While the old 8-bit GRBL has a lot of limitations, the "HALified" 32-bit version has removed them - most notably, step rates of over 200 kHz are supported, you can have up to 6 Axes and Ethernet interface. It runs on a wide range of microcontrollers - 13 at latest count. You can find out more about it here: https://github.com/terjeio/grblHAL. No SW license fee required - it is opensource. The test branch has autosquaring for ganged axes (like you recently moved to) and a really nice configuration section. It should be moving over to the master branch in a week or so. I'm running it on my small router. Several people are running it on ganged axis machines like yours. I have a breakout board on Tindie for the Teensy 4.1 (600 MHz ARM Cortex-M6 processor) - https://github.com/phil-barrett/grbl...ster/README.md. I call it an unkit - all SMD components are there, you just add easy to solder through holes components like connectors and the Teensy. All in cost including connectors and the Teensy is about $65 USD. Though, schematics, gerbers and an OSHPark upload are available if you want to build your own. Worth checking out.
    Sep 2020
    7
    Quote Originally Posted by philba View Post
    Hi
    I need help
    I have got cnc machining center with fanuc m15 control
    I lose all parameters
    I need parameter manual
    I won't to adjust number of axis
    Now only x axis appears on screen
    Please send me how to solve this problem
    Sep 2020
    81
    Hi Philba,
    Thank you for your input. The mentioned controller is way costlier here in my country..around 300 USD.
    I have Mach3 parallel port one but I didn't knew it won't through USB.
    15362
    Hi Philba,
    You can use Mach3 with a USB or Ethernet you just need something like a Smooth Stepper which came in both USB or Ethernet, Ethernet being the best choice, or a cheaper option a UC-100 this is very good
    CNCdrive - motion controls
    Mactec54
    Sep 2020
    81
    Unfortunately the UC100 is also about 100 USD here. I have decided to ditch the parallel port one buy the USB Mach3 one (runs on external power and data transfer through USB). Lets hope that works.
    Sep 2020
    81
    So I put in a lot of time is refining and calculating/designing the specifications of the router. Now it is in much better shape. Here are some pics.
    I still need to work on the height as I have around 160mm of travel through the lead screw but the current gantry height is giving me just 80mm. I made some calculation mistake it seems. Need to correct the gantry height so that I get close to full travel.
    I have been mixing X and Y axis in my earlier conversation. The long axis travel is around 900mm and the cross is about 600. Z axis should be 160mm (need to alter height of Gantry as mentioned)
    how does this look? I welcome any suggestion.
    Attached Thumbnails Attached Thumbnails Capture3.PNG   Capture4.PNG   Capture5.PNG
    May 2004
    210
    $300? For the one I showed? Hmmm, it's around 65 USD. $26 for the breakout board from Tindie. $26 for the teensy and 12 or so for the misc parts. Shipping and customs depend on location but $200+?
    Sep 2020
    81
    I can get it shipped from other countries but the shipping is not reliable at the moment due to COVID and also charging high then normal. This is unfortunate but this is what it is. I inquired local CNC shops. They are industrial shops and use very sophisticated looking drives and breakout board. way above then what I need.
    Jul 2018
    6492
    Hi TS - You will need two bearings on your long axis. It will rack and wear quite fast with one (from experience on my first router). Plus I recommend getting high preload bearings. Normal zero clearance bearings will develop clearance in about a years of use. Peter
    I see you only have one car on each rail, sorry you will need 2 bearings per rail. They need to be at least one bearing length apart prefer more. Cars are cheap its the rail thats $$$. If cost sensitive then fall back to round rails, they are about half the cost of square ones but they are not as stiff.
    Sep 2020
    81
    Hi Peter,
    Many thanks for the advice. I am little unclear on 2 bearing on long axis comment. By 2 bearing you mean 2 ball screw nut on ball screw? or 2 BK support?
    About car, i understood. I initially had 2 cars on each rails for X & Y. I will revert to that design. Do I need two cars on each rails of Z-axis too?
    The stiffness of round rails has prevented me to have it. Will try accommodating on guide rails only. Cost is offcourse a factor but let me see how far I can push it.
Page 1 of 8 123
  1. Replies: 0
    Last Post: 07-11-2020, 05:14 AM
  2. Can a wood router cut aluminium?
    By chinsettawong in forum DIY CNC Router Table Machines
    Last Post: 08-19-2017, 03:22 AM
  3. CNC Router build using aluminium profile.
    By 142victoria in forum DIY CNC Router Table Machines
    Last Post: 06-08-2015, 06:40 PM
  4. Aluminium router build from Drakkn
    By Drakkn in forum CNC Wood Router Project Log
    Last Post: 06-19-2011, 07:19 PM
