587,776 active members*
2,519 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Matching drives to old AC servos?
Results 1 to 5 of 5
    Jul 2009
    85
    I have a dyna mechtronics dm4400m with the following motors that I would like to reuse, or replace with similar servos.
    Any good source for ideal replacement drives at an economical price for the home hobbiest ?
    X-Y axis
    HA40CS
    Rated Torque
    30.0 kg/cm at stall (2687 oz.in.)
    27.2 kg/cm at 1000 RPM
    24.4 kg/cm at 2000 RPM
    Max. RPM 2000
    Weight 8 kg
    Z axis
    HA80CS
    Rated Torque
    60.0 kg/cm at stall (5375 oz.in.)
    54.4 kg/cm at 1000 RPM
    48.7 kg/cm at 2000 RPM
    Max. RPM 2000
    Weight 12kg
    Dec 2003
    24220
    Re: Matching drives to old AC servos?
    Albert E.
    Jul 2009
    85
    Yes there are lots of posts about the 4400m I have gone through that and several others to gather as much information about it as possible to see what I could make fit.
    They talk about granite drivers but I’m not seeing any success recently with driving the original motors.
    Thanks for the link
    Duke
    Nov 2013
    4551
    unless you're 100% familiar with servos with their associated encoders and/or resolvers sounds like a good recipe for spending lots of money
    buying new drives for your existing servos only to find they do not match each other as well as you hoped.
    If you are new to AC servos do yourself a favor and buy a matched pair, that is the servo AND the drive. Delta (Taiwanese brand made in China) and
    DMM (Canadian brand made in China) are two good quality brands that perform well, are well supported at reasonable prices.
    Craig
    Jul 2009
    85
    Craig
    I am a lot more comfortable using steppers than servos of any flavor.
    But as I understand a mill the size of the dm4400 runs best with servos so should I embark on learning servos, or could I get a big enough set of closed loop steppers to get pretty good performance out of this thing?
    Duke
  1. DC servos and drives
    By seapacer2 in forum For Sale Only
    Last Post: 02-18-2021, 11:48 PM
  2. Servo Drives and Servos
    By jasonGO in forum Servo Motors / Drives
    Last Post: 05-02-2020, 02:54 PM
  3. servos, drives, p/s
    By scudzuki in forum Benchtop Machines
    Last Post: 02-09-2009, 01:02 AM
  4. Inductance matching drives?
    By pdunster in forum CNC Machine Related Electronics
    Last Post: 09-07-2006, 12:01 PM
  5. servos (encoders, drives)
    By gv71 in forum CNC Machine Related Electronics
    Last Post: 03-31-2004, 07:43 AM
