587,481 active members*
3,062 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Jul 2018
    47
    Spindle Control Follow-up
    Tom
    Thank you so much for the help , i think i have it where it is workable , now to set it up in Kmotion.exe
    i have set up M3,M4,M5 and S in the tool setup , using your example in the CSS folder and the Motor starts and changes direction . but it doesn't Stop or display speed.
    i have the FACTOR set at 50 holes*4 edges = 200/60 or should i be using a different format as i read somewhere 1=3750 or 20157 = 3750
    i think i have read so many posts and guides now that i am confusing myself.
    I have also used the basic control example for spindle control , exactly as in the Manual just changing the bits to 154 and 155 and DAC =0
    the spindle also starts both CW and CCW but doesn't stop or display speed . when i start the spindle it also goes full speed even if i set S=500 in the gcode
    (Edit Png shows min 0 and max -2047 ,, i have tried with these values transposed and outcome is the same)
    regards
    Sean
    May 2006
    4048
    Re: Spindle Control Follow-up
    Hi Sean,
    No writing to the DACs is another method that can be used if you don't have any feedback. We went through all the trouble to get the spindle so it could be commanded like an axis so the axis would write to the DAC to maintain exact speed and ramp in a controlled manner and so forth. So configure to use the C Programs that do Jogs to an axis as described here. Note it describes to set USE_POS_NEG_VOLTAGE to 0 if you have a system like yours that can only use positive voltages for both directions.
    To have KMotionCNC display actual Spindle Speed configure KMotionCNC | Tool Setup | Trajectory Planner | Threading as described here.
    TK
    http://dynomotion.com
    Jul 2018
    47
    Tom
    first link doesn't seem to work https://www.cnczone.com/forums/newre...reply&t=422508
    Sean
    Jul 2018
    47
    Hi Tom
    Same result as my previous try's , will turn on ok, but not stop ,
    with trajectory screen @ 200 cnts/rev ,kmotion screen reads 70 rpm when S is set to 100rpm actual spindle speed 3750rpm
    Sean
    May 2006
    4048
    Opps here
    TK
    Jul 2018
    47
    Tom
    #define PC_COMM_CSS_S 113 // S speed setting in inches/sec
    Wasn't in the PC-DSP.h that i could find . i have added it and the change from CW to CCW is slower now like it is ramping down the speed and then back up rather than an instant relay change over , but the spindle speed doesn't actually change .
    Jul 2018
    47
    Quote Originally Posted by TomKerekes View Post
    Opps here
    This is the article that i have been following since last Friday , have tried all methods suggested and cannot get S to change it is always full speed in kmotion.exe ,. jog3=?? and DAX0=?? works over the full speed range in console
    Have today removed everything inc Kmotion from the PC , reinstalled Kmotion ,so starting afresh and have only DAC0 connected and is the same
    May 2006
    4048
    Hi Sean,
    That's very strange are you sure? What Version of KMotion are you using?
    The Tool Setup Screen you posted yesterday was all wrong as it was setting IO Bits and DACs rather than running C Programs as described in the article. Please re-post how you have now configured your Tool Setup | M0-M3 screen.
    TK
    Jul 2018
    47
    Version 435f i have used find command in word (Edit -Notepad) on both PC-DSP.H files one in DSP-KFLOP and DSP-KMOTION folders and that line is not present
    screen shot of the Tool setup page attached
    Sorry i attached the other one yesterday was long day, i set up like that because i wanted to see if i could set speed on the KMOTION screen with spindle set as DAC0 , worked in console but not KMOTION
    and with drive set as Axis 3 JOG functions work in console but not in KMOTION
    Both setups just give a full speed motor regardless of S= in KMOTION
    May 2006
    4048
    Hi Sean,
    Its in DSP_KFLOP\PC-DSP.h line 248
    Attachment 467198
    The configuration of the Actions looks now correct.
    What prints on the Console?
    I realize now we may have a problem running in one of the directions. With USE_POS_NEG_VOLTAGE set false the programs will always Jog positive. But with different CW CCW bits set the Spindle will run negative and the encoder will count negative. This will result in a positive feedback runaway. I think in one case we will need to reverse the input gain.
    But I would expect one direction to work correctly. Have you tried starting from stopped each direction?
    Are you able to control the Spindle both directions from the Console using Jogs and setting the CW and CCW bits? You might want to Zero the axis before starting.
    TK
    Jul 2018
    47
    Good Morning Tom
    Found it thank you
    Screenshot of console attached
    yes i have started both directions from stop , and as you have stated in CCW, position and counts are same direction and CW counts stay positive encoder goes negative
    Yes i can control the spindle in both directions from the console using DAC0 and JOG3
    FROM THE CONSOLE
    i Think it is a scaling error somewhere as any thing above JOG3 = 250 goes full speed , At JOG3 = 200 Spindle is stable at 3000 Rpm (maximum speed is 3750)
    FROM KMOTION
    S=200 goes full speed in both directions and console says jogging spindle @ 300 counts/sec
    OFF Button clears both bits but doesn't stop the spindle
    hope this is more helpful
    Sean
    Jul 2018
    47
    Tom
    Note as wouldn't let me edit above post
    Spindle max 3750rpm with motor @ 7150 rpm
    May 2006
    4048
    Hi Sean,
    FROM THE CONSOLE
    I agree.
    200 should be 1 rev/s or 60RPM so its off by a factor of 50. Is the Input Gain still 0.02? Post your Configuration Screen and Init C Program.
    TK
    Jul 2018
    47
    Tom
    Yes Scaling is still -0.02 as in the step/response screen that gives the encoder the correct reading on the axis screen
    Config and Init File attached
    Sean
    Attached Files Attached Files
    May 2006
    4048
    Hi Sean,
    Those look to be both as expected. I was thinking the default of 1.0 vs 0.02 would be a factor of 50 as observed but that should actually make it run 50X slower not faster. Maybe only 1 hole is being picked up by the sensors? That would cause a factor of 50 faster.
    You'll have to do some trouble shooting and sanity checks.
    You might:
    #1 cycle power on KFLOP
    #2 Run the Init Program from KMotion.exe
    #3 set whatever Direction Bits needed to run positive
    #4 Record from Axis Screen Dest and Position (should be near zero)
    #5 Command Jog3=100 on Console. Should be 30RPM but you indicated this runs spindle at 1500 RPM. Time this for 1 minute. Do you have another means of measuring RPM?
    #6 Command Jog3=0 on console for to stop. (note approximately how long to stop)
    #7 Record from Axis Screen Dest and Position (if running @ 1500 RPM that would be 1500 revs x 200 counts/rev = 300,000 counts)
    TK
    Jul 2018
    47
    Don't think its just picking up one hole , if we take measurement below 1680rpm @ jog3=100, 50 holes in disk
    (1680 x 50) / 60 = 1400 . scope measured 1.34 - 1.42 KHz
    You might:
    Done
    I Don't have another tachometer that works . i have set up a closed loop maxon motor today and checked my Tacho (smiths industries mechanical tachometer) .
    JOG3=100 measured 1710rpm on the spindle , against the maxon motor 1710rpm =1685 rpm[/QUOTE]
    Dest = 6072 Position = 6083 1min run + approx 3 secs to stop (screen shot attached )
    so we are about 50 times slower as you pointed out.
    Sean
    May 2006
    4048
    Hi Sean,
    Duh of course, I wasn't considering properly the Input Gain of 0.02
    1500 revs x 200 counts/rev x 0.02 scale = 6000 Position units
    Please include * 0.02 in the FACTOR. Or change the 200 to 4.0 (the decimal can be important to force floating point math).
    Also change the Trajectory Planner Threading Configuration from 200 to 4 to correct the RPM readout, There are 4 units per rev.
    On a side note somehow I think missed this earlier scope trace.
    Attachment 467296
    One thing I see it that the sensors are not indicating a good 90 degree phase shift well. Towards the middle they are almost in phase which could cause errors or counting backwards. You might try to adjust that.
    TK
    Jul 2018
    47
    i cant seem to find where the FACTOR value is is the 200 that needs changing V =200 in the step/response screen ?
    This works perfectly
    Attachment 467296
    i will check into this , also on the last check when i was measuring the frequency , trace was a little noisy
    May 2006
    4048
    Hi Sean,
    In MySpindleDefs.c change
    #define FACTOR (200/60) // to convert RPM to counts/sec (counts/rev / 60.0sec)
    to
    #define FACTOR (4.0/60.0) // to convert RPM to units/sec (units/rev / 60.0sec)
    TK
    Jul 2018
    47
    Tom
    Works almost perfectly :-) , thank you
    S =1000
    in CCW ramps up nicely to roughly 1200 then down to 900 and then stabilizes at 1000 +/- 20 rpm and ramps down to Zero when the off Button is pressed .
    CW just runs away as count is wrong direction
    Sean
Page 1 of 2 12
  1. Replies: 1
    Last Post: 03-20-2021, 06:52 PM
  2. MACH3 SPINDLE CONTROL - CONTROL BOARD HELP
    By tuning_cnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-20-2016, 04:37 AM
  3. Modbus TCP with Control Techniques SK Commander VFD for spindle control
    By fishin_fl in forum Mach Software (ArtSoft software)
    Last Post: 08-26-2013, 04:07 PM
  4. Follow up on V2XT program repeat with spindle left on.
    By ncpapaul in forum Bridgeport / Hardinge Mills
    Last Post: 04-01-2010, 02:47 AM
  5. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
