587,201 active members*
3,044 visitors online*
    Sep 2014
    66
    Question what's the non-wire?
    Hi.
    In shortening the cable carrier over the Z steppermotor I cut the power cable to the spindle with a view to re-joining it ( to give a shorter overall length) rather than undoing the whole drag chain assemblies from the spindle right back to the 'box' - and I found 4 wires red blue green yellow plus the shielding but in the middler of the four wires there's a fifth 'non wire in a plastic 'sheath' which appears to be some soft fibrous material.
    Can anyone tell me what it is and what's it there for?
    Thanks,
    Rob.
    Dec 2013
    5714
    Re: what's the non-wire?
    It's called a filler. That is exactly what I does, it fills extra space in the cable.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2014
    66
    thanks for filling me in...
    Dec 2013
    5714
    Quote Originally Posted by RobSm View Post
    I see what you did there
    Jim Dawson
    Sandy, Oregon, USA
  1. Mitsubishi FX-10 1997, Problem with wire detection before the wire chopper.
    By Jeff247 in forum EDM Discussion General Topics
    Last Post: 10-29-2019, 03:26 PM
  2. Stepper tap wire and spindle ground wire connection
    By cncuser1 in forum Gecko Drives
    Last Post: 02-16-2019, 02:53 AM
  3. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  4. USER MANUAL SODICK MARK X or XI wire EDM, and wire breakage
    By stan34 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2015, 03:56 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
