587,302 active members*
3,157 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Help! Brother TC229 cnc-620 spindle amplifier pinout.
Results 1 to 3 of 3
    Jul 2021
    8
    Hi All!
    I have an old Brother TC229 control board (B52J057-1) with the 4 output connectors (20pin) for the X,Y,Z Axis and the Spindle. I know it belonged to a CNC-620 control system. I have the original spindle amplifier (Sanyo Denki PE0A150Mxxxc00) for the board and the spindle motor as well. Fortunately I have the power cable and encoder cable too, so actually I have everything I need.
    I don't want to use the original board for controlling the amp and the motor, I'd like to use an other card using pulse/dir or analog (+- 10V) contol. But unfortunately I have no information, about the pinout of the I/O connector (CN1) of the amplifier! In the Sanyo Denki Pe manual, the CN1 connector is a 50 pin connector, but mine is just a 15 pin connector, so I can not figure out the pinout from the manual.
    Can anyone explain or measure me the pinout of that CN1 I/O connector????
    I'm looking for pins like (SON (servo on), SG (ground),VCMD (analog velocity command)!
    I"d be very thankful!
    Jul 2021
    8
    Re: Need Help! Brother TC229 cnc-620 spindle amplifier pinout.
    A little update on the Thread!
    I've already got the relation of the connctors and now I just need to figure out how I could use them to control the spindle drive.
    NC Board ----- Spindle Drive (CN1)
    1 ----- 1
    3 ----- 2
    5 ----- 3
    7 ----- 4
    10 ----- 5
    13 ----- 6
    n/a ----- 7
    n/a ----- 8
    2 ----- 9
    4 ----- 10
    6 ----- 11
    8 ----- 12
    11 ----- 13
    12 ----- 14
    9 ----- 15
    I still don't know the control method is analog or digital!
    Jul 2021
    8
    Update Again!
    The control board with the 20 pin connectors for X,Y,Z drives and for Spindle is a Brother CNC-820 controller!!!!!!!!
    So the first information was totally wrong!
