603,942 active members*
2,627 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emco PC Turn 55 backlash Z axis
Results 1 to 6 of 6
hugoturn Emco PC Turn 55 backlash Z... 07-28-2022, 11:21 PM
hugoturn Re: Emco PC Turn 55 backlash... 07-28-2022, 11:40 PM
hugoturn Re: Emco PC Turn 55 backlash... 07-30-2022, 05:08 PM
Jim Dawson Re: Emco PC Turn 55 backlash... 07-30-2022, 05:20 PM
hugoturn Re: Emco PC Turn 55 backlash... 07-30-2022, 08:55 PM
Jim Dawson Re: Emco PC Turn 55 backlash... 07-31-2022, 03:16 AM
    Aug 2019
    5
    Hello everyone !
    I am doing a retrofit of an Emco PC Turn 55 and I see that in the Z axis it has a backlash of 0.02mm (In the X axis there is no backlash)
    Attached photo of the Z axis ball nut support.
    Does anyone know how to adjust the preload on this ball nut? There are three screws, two hex head and one slot.
    Hugo Gonzalez
    Aug 2019
    5
    Re: Emco PC Turn 55 backlash Z axis
    Some photographs
    Aug 2019
    5
    Hello !
    Could someone send me a photo of the Z axis ballnut because I have doubts that the one I have is the original?
    That photo may be of the "PC Turn 50 or 55" or "Concept Turn 55"
    Thank you
    Hugo Gonzalez
    Dec 2013
    5720
    If it is not a double nut, then the only way to preload it is to install larger balls. Not an easy task. I can't see enough of the nut in the picture to say what it is.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2019
    5
    The ballnut that I have installed on the PC Turn 55
    Is it the original or has it been changed?
    Dec 2013
    5720
    Sorry, I don't know
    Jim Dawson
    Sandy, Oregon, USA
  1. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  2. EMCO PC Turn 50
    By bluepgt in forum EMCO Lathe
    Last Post: 02-02-2012, 10:27 PM
  3. RFQ - Program Emco 7 Axis Mill/Turn
    By C5Frenzy in forum Employment Opportunity
    Last Post: 09-19-2009, 04:48 PM
  4. EMCO PC Turn 55
    By CatBurke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2008, 08:21 PM
