588,616 active members*
5,504 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > My machine is not cutting the distance I tell it to
Results 1 to 13 of 13
    HI there, I have a G0704 with 5tpi ballscrews running a Gecko g540 and ESS through Mach 3. My steps per inch are set to 10,000. I am using FreeCad to design and generate G-Code.
    I was milling this part, and instead of milling the entire width of 5.5 inches, it only came out to about 5.4 inches. And the little cylinders on top are 1.082" diameter instead of 1.125" diameter. Can anyone please help me figure out what the heckin' heck is going on?
    Jan 2013
    474
    Quote Originally Posted by TransJenna View Post
    Check your x/y axis motor couplings for play or damage. Check your x/y axis for backlash (lost motion).
    Check the squareness of spindle head to Z axis in case it has pitched over at an angle.
    Do a spindle trammell check to the table top.
    Re: My machine is not cutting the distance I tell it to
    I've tried those things already, as well as checking the gibs for slop/wear. Everything checks out.
    Apr 2022
    140
    If the calibration in mach3 checks out then check the play of the head and if your cutter is the right size.
    You can check the gear ration setting for the affected axis.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    15362
    Quote Originally Posted by cncmakers001 View Post
    There are no Gear Ratio settings for axis settings.
    Mactec54
    Feb 2008
    521
    Are you sure they are inch / imperial screws? A metric screw used with imperial settings would give a similar error ie. a 5tpi screw = 5 turns / 1 inch, a 5mm pitch screw x 5 turns = 25mm which is 0.4mm shy of an inch!
    Dec 2013
    5722
    Quote Originally Posted by kawazuki View Post
    What kawazuki said ^^^^^^^^^^^^^
    A 5 TPI (0.200'' lead) ball screw is a bit unusual, but not impossible. Much more common is 5mm lead (0.197'')
    Jim Dawson
    Sandy, Oregon, USA
    Now I am second guessing myself. It has been a few years since I bought the leadscrews. They very well may be 5mm pitch. Hopefully that is the issue!
    So what would that make the steps per inch setting? 10,152? It is a direct connection to from the motor to the leadscrew. So it should be 1/.197=5.076x2000=10,152.... right?
    Nov 2012
    1281
    10160 steps per inch would be the correct number for 5mm screws.
    200 (steps per turn) * 10 (microstepping) / 5 (mm per turn) * 25.4 (mm per inch) = 10160.
    15362
    A calculation will get you close, once you figure out what your Screw pitch is, then you go through the setting of each axis doing the Steps Per with the control, that's if you want any kind of accuracy.
    Do you have Leadscrews or Ballscrews??
    If there is a part number on the Nut this normally includes the screw pitch in the number, you could have either type of Leadscrew ,200" or 5mm you can find either pitch with Leadscrews or Ballscrew, most Leadscrew / Ballscrew manufacturers make both inch and metric.
    Post the part number on the Nut we will see from that what the pitch is.
    Mactec54
    15362
    You will have to check the Step /Per, using the setting of10,000 may not be correct, it is rarely an exact number like this, the longer the setting piece you use to set the Steps / Per the more accurate it will be, you can use a micrometer setting rod, you can find them quite cheap on Ebay, 255950327179 this is 8" but 12" is better, depending on your axis travel, you can also use a 1 2 3 Block or Gauge Blocks, the longer the test measurement the more accurate you will get each axis, you can do a rough check with a steel scale (Ruler),and a pointer in the spindle
    You will find in Mach3 the Axis Setup, Steps / Per by using the settings Tab, across the top of the Mach3 screen. there are videos on how to set the Steps / Per on YouTube there are different ways that are used so just use YouTube as a guide.
    Mactec54
    the first thing I'd do is put a dial indicator on it . If it looks good then it's quite possible the code is the problem
  1. Mach 3 cutting half the distance/size
    By SRTCNC in forum Mach Software (ArtSoft software)
    Last Post: 12-29-2016, 12:32 PM
  2. Vector cutting distance
    By jdoon5261 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-10-2014, 06:01 AM
  3. Distance from cutting bed to drop tray?
    By Things in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2012, 06:39 AM
  4. distance between computer and machine?
    By geekinesis in forum Stepper Motors / Drives
    Last Post: 02-06-2011, 03:01 PM
  5. Replies: 1
    Last Post: 09-05-2008, 04:15 PM
