588,254 active members*
5,516 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam 2017 Gcode issue
Results 1 to 3 of 3
    Mar 2011
    230
    Hi Guys
    Basically, milling a rectangle (test) 1mm deep (so basically 2 cuts) (250mmX145mm) at 0.5mm increments using dynamic contour milling in 2D.
    This should be a short straight forward G code program but when I generate the G code its thousands of lines of code and each axis traveling in a straight-line X and Y shows coordinates traveling 0.1mm at a time each line of code. (Explains why the G code is so long).
    Just wondering what I'm doing wrong, is there a setting or am I just using the wrong milling function i.e. not dynamic contour milling???
    Thanks guys.
    Bart
    Dec 2008
    3138
    Re: Mastercam 2017 Gcode issue
    Yeah....
    You have realised it is a simple path you need
    ...so...
    A simple 2D_Contour operation using wireframe geometry. Set the operation parameters as required.
    Remember to NOT tie yourself into knots by setting everything you can see on the more complicated ops, as too much setting can block some paths from actually giving what you are really needing.
    Here is a hint that many don't know...where milling stock material is defined
    Facing operation with NO wireframe selected actually uses the stock material as the boundary.
    Mar 2011
    230
    Ok cool.
    I just realized i can use slot mill in 2D with 0 overstep
  1. Mastercam 2017 5 AXIS
    By asmanss in forum Videos
    Last Post: 11-05-2016, 08:55 AM
  2. Replies: 0
    Last Post: 10-27-2016, 09:28 PM
  3. Replies: 0
    Last Post: 09-14-2016, 08:15 PM
  4. Replies: 0
    Last Post: 06-27-2016, 05:43 PM
