587,401 active members*
3,191 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > .625" thick access door plate mod 1100 series 3
Results 1 to 2 of 2
    Oct 2006
    71
    I recently picked up an 1100 series 3 machine from a lab that I occasionally purchase tech assets from. Ive never had a hobby grade machine since I started using CNC in 1999. We have 2 DMG Mori VMCs a 5 and a 4 axis here but this was almost a freebie so I figured why not. Good for training on anyway. Made some test cuts and about what I expected, thinking about maybe selling but then I saw the cnc cookbook mod to the rear access door.
    Took a .625" plate and made a rear access door with 8 holes for 5/16 bolts. Face milled the contact side. Drilled and tapped the casting all the way through. I used a torque wrench to tighten. Wow, it actually made a difference, especially in steel. Definitely keeping the machine for small parts and training. I recommend the mod! I dont know how many others have tried this, I could only find the one mention and photo, no attribution.
    Jan 2006
    58
    Did the plate improve the X&y accuracy ?
  1. new departure nut mod on a series 3 1100
    By popspipes in forum Tormach Personal CNC Mill
    Last Post: 12-02-2022, 05:09 PM
  2. 1/4" to 10 mm thick steel plate
    By kdoney in forum RFQ (Request for Quote)
    Last Post: 12-15-2011, 07:35 PM
  3. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  4. Simple 1/4" thick 6061 plate
    By Aaron92SE in forum Employment Opportunity
    Last Post: 05-16-2008, 10:47 PM
  5. Width of door for Series 1 access ?
    By Number Six in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2007, 10:00 AM
