Hi
Can anyone help me with parameter settings for RS232. I have try (PIP) commando then write X CN0: I get 320 error RS232C not ready.
Cable is connected like picture
krg
Goran G
Hi
krg
Goran G
Try...
PIP >> CN0:, >> WRITE
this should allow any file to be saved as A.MIN in the control, if your settings (& cable) are correct.
...you have to type the file name also to Punch and double check cable.
https://www.aggsoft.com/cnc-dnc/okum...a-osp-7000.htm
Hi again
So if my file on PC is part2.min i need to write this after CN0: Part2.min write ? How can i make CN0: RS232 ready ?
Which communication program do you use on the PC side?
"Imagination is more important than knowledge."
Hi i use dnd4u
dnc4u ?
Yes sorry.
All communication settings must be same on PC & OSP side and must give send/start command on pc after sending receive command on osp in the timeout value time
This is my settings
Do you know how to modify P200 system PLC?
I would try to set bit 1 to 0, which responsible for internal / external ready. All the rest can be as they are.
But the very first point is to check the cable. Because this "not ready" message is so strange.
Did you tested the communication via that cable let's say between to PC's with Hercules utility?
Hi i have try this but no change...I´m not sure if i have right pin connected. If i read manual contact show one type and net show different pin. i Try Hercules utility and port com 3 send correct.
...set Data Bit to 7, Parity to Even, Stop Bit to 1, Flow Control to Xon/Xoff.
then,
Sending to the PC Go to the 'Edit/AUX mode', [F3] (PIP), [F2] (Punch), type file name, then [Return] or [Write]
Reading from the PC Go to the 'Edit/AUX mode', [F3] (PIP), [F1] (Read), [Return] or [Write]
If, that does not work....double check Comm Port number on PC by Holding down the Windows Key type R ....a Run window should popup then type "devmgmt.msc" Hit OK then look for Com Port List.for the DNC4U device.
DJ
Thanks i will try later today.
Contact in the picture from Okuma MX45. Which hole is No. 1 ? On the internet, the pin configuration is not the same as on the machine for D25.
