587,380 active members*
3,494 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Machine won't respond to part zero properly!
Results 1 to 2 of 2
    Oct 2023
    I'm currently enrolled in an Industrial Maintenance class and am working through CNC Operation. The big issue with that is the CNC not responding to the workpiece zero.
    The machine, a Levil WL-F400, has a Fanuc Series Oi Mate-MD controller. Going through the lesson, it has me set G55 as the workpiece zero using an edgefinder, and the X and Y zeros work properly. The issue with the Z axis. Despite setting the Z axis for G55, the machine sets the Z axis for way lower when actually running. The same code that will position it right above the corner of the workpiece will also cause it to overrun on Z.
    Oct 2023
    Re: Machine won't respond to part zero properly!
    This has been solved! There was a value in the EXT offset when it should have been cleared, leading to the machine offsetting what the workpiece zero should have been.
  1. Rrouter won't respond to mach3
    By Kohly in forum Mach Software (ArtSoft software)
    Last Post: 03-18-2021, 08:35 PM
  2. Replies: 2
    Last Post: 11-03-2017, 09:02 PM
  3. NEED HELP PLEASE - Motors on CNC won't work properly
    By jazz352060 in forum Australia, New Zealand Club House
    Last Post: 07-14-2010, 08:08 AM
  4. X4 won't regenerate properly
    By kprice1658 in forum Mastercam
    Last Post: 04-03-2010, 08:16 PM
  5. Machine won't cut out my part!
    By CROSSHATCH in forum Uncategorised CAM Discussion
    Last Post: 01-08-2008, 01:41 AM
