587,997 active members*
2,022 visitors online*
Results 1 to 3 of 3
    Mar 2016
    13
    WinCNC Tool Setup
    Evening all, Hope all is well??
    I have aquired an Exelcnc 1224hd atc running WinCNC. As a veteran of Mach 3 and a non ATC machine I have hit a hurdle that in my mind is very simple to sort just i cannot transpose it with wincnc,
    I am confused onto how i set up the tool changer, I have a milling machine with an ATC that i can zero each tool in to the work peice and i dont have to worry.
    where as the win cnc i zero'd each tool but it doesnt seem to save the heights.
    I have added an 18mm spoilboard so I need to zero that as my zero but how do i then get it to measure the tools?? I have a tool pad for the tools to touch off but i dont have a clue, all instructions that have come with the machine do not mention anything about setting up my tools.
    Any help will be greatly received thank you
    regards Tom
    Mar 2009
    1982
    Re: WinCNC Tool Setup
    1. Touch with the tool the surface of workpiece.
    2. Set tool length = height of the workpiece.
    3. Check the tool tip against the table surface = 0.
    Mar 2016
    13
    Hi Thank you for this info,
    Managed to sort it thank you
  1. creo tool setup 4 axis - tool GAUGE Z lenght
    By haasab in forum PTC Pro/Manufacture
    Last Post: 09-09-2015, 08:31 PM
  2. Replies: 3
    Last Post: 05-25-2015, 04:25 PM
  3. tool setup
    By msdeltaguy in forum Vectric
    Last Post: 01-06-2012, 12:44 AM
  4. Tool Setup
    By stevieboy in forum HURCO
    Last Post: 07-11-2011, 12:59 AM
  5. need help: touch probe wincnc.ini setup
    By santiago lisboa in forum WinCnc
    Last Post: 02-20-2009, 04:06 AM
