587,613 active members*
4,632 visitors online*
Results 1 to 20 of 22
    Oct 2005
    118
    Feeds & speeds Question
    Hey all, I have a question for you. We have a piece of 316 stainless that has to go on a BIG diet, Sooo we have decided to put the shell mill on the job. But...... I would like to get a good starting point with the speeds and feeds. We typically run a TON of aluminum so this stuff is a bit new to me.
    Thanks Janos
    Feb 2006
    42
    A little more info would help. What diameter face mill? How many inserts? What size machine?
    Oct 2005
    118
    Ooops, sorry!! Had a very long day and I wanted to end it.
    3" Valenite sheer mill ( I will have to get back with you on the inserts. )
    6 inserts
    Haas VF-4 w/ 20 Hp
    Right now it has a castrol lube in it fo alum but when we just faced the part the cuttung edges got wiped out.
    Thanks janos
    Feb 2006
    42
    I run 316L alot. I run a 3 inch face mill(6 inserts) at 250 rpm and 5 ipm on a VF3SS. I'm cutting .213 off a part that is 2.5 inches wide. I take it in two steps of .106 I can cut about 40 parts like that. Obviously you can go a little faster but your tool life will suffer.
    I am using RTW inserts. The part number is SEHW43A6. Hope that helps.
    Oct 2005
    118
    Quote Originally Posted by cutting edge View Post
    The guys I am asking the info for got a .750 valenite indexable shoulder mill and went by what the salesman suggested which was 900 rpm and 15. ipm at .03 deep and quickly dispached a set of inserts. I took your info and adjusted them to the new tool and it seemed to work quite nicely. It was still buzzing along when I left it.:wee:
    What kind of coolant do you use for it? They bought a Castrol product that is clear. The kind we use at my day job is Basocut Swisslube (I think my spelling is correct) It works great on pretty much everything.
    Thanks Janos
    Feb 2006
    42
    Quote Originally Posted by Janos View Post
    Thanks Janos
    I use Blaser BC40 NF. I am currently running the stainless job that I told you about. I tried something a little different. I was just running a clean up pass on the part and ran the 3 inch face mill at 509 rpm and 18 ipm with a depth of cut about .020. Part is 2.5 wide and 6.25 long. I ran about 60 parts like this before the inserts let go. I haven't tried taking the larger cut yet. Will report back later.
    Glad to hear that worked for your friend!
    Oct 2005
    118
    Thanks, I appreciate you help!:cheers:
    Janos
    Oct 2006
    586
    This is what my software put out it is pretty accurate you may change a bit as was said for tool life
    Attached Files Attached Files
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Nov 2007
    21
    software
    Quote Originally Posted by jackson View Post
    what type of software is it and whats it called. and were can you get it.
    Oct 2006
    586
    Quote Originally Posted by DONNYBRASS View Post
    http://www.mrainey.freeservers.com/ Here is the site i recommend getting the ME Consultant Pro & ME thread Pal as you will see from the site they are worth the money
    Nov 2007
    479
    Might want to run that dry as well. I face mill 304 structural at work and run it dry with good results. The coolant might be shocking it to much, and make sure your using a tough ss grade like vp5135.
    Aug 2005
    578
    I have a recurring job in 316. Nasty stuff. I have a 2 1/2" face mill with round incerts. SECO REHR 1605M0T m14 T25m. I turn these at 382 rpm and feed it at 6 to 8 ipm. Takes .100 a pass full width. I can buzz along for quote a while before I have to turn the buttons.
    Oct 2006
    586
    And for the coolnt question i use Qualichem Q-cut 250 i went with it over the blaser for one i dont like the guy that sales it here and i tested the Q-cut and it improved my tool life in my lathes by 40% and my mills by 50% and i run brass, alum, 12L14, 303ss, 316ss, ext and i run them all at refract of 5 mills and lathes both, i have 8 cnc machines and a drum last me well this one has lasted 7 months time for a new one i try to change out tanks every 6 months or so this stuff really dos not seem to get as used as some of the other coolnts i have used.
  1. tungsten feeds and speeds question!?!
    By dcrblazer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2014, 01:53 AM
  2. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  3. Speeds and Feeds
    By wdp67 in forum Benchtop Machines
    Last Post: 07-10-2007, 08:06 AM
  4. feeds and speeds
    By JpBinc in forum MetalWork Discussion
    Last Post: 10-03-2006, 06:48 AM
  5. feeds and speeds
    By Mortek in forum Hard / High Speed Machining
    Last Post: 02-28-2004, 10:59 AM
