588,189 active members*
4,482 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > software/tool to convert spline in to polyline of arcs and segments
    Feb 2007
    36
    Is there a tool to perform this process: convert all spline of a DXF file in to polylines made also of arcs, with control on error or deviation?
    i have problem to use the command Pedit, it's results are totally unpredictable
    Thank you
    Dec 2008
    3136
    Re: software/tool to convert spline in to polyline of arcs and segments
    Do a google search for "autocad break polylines into arcs"
    Should give possible solutions for AutoCAD.
    Look for how to "break" an item into another entity type, it should also have a tolerance of maximum deviation from the original.
    Jul 2018
    6520
    Hi Balestraio - If you are going to break a spline into smaller pieces , only break into lines not lines and arcs. This will give you much more consistent result. Pick a suitable line length for the conversion that meets your tolerance requirement. A spline will never have an "arc" in it and when converting to arcs you will get 1000's of small arcs to achieve your tolerance, then the motion planner will break the arcs into smaller lines again and it will bog your machine motion down. Peter
    Jun 2015
    4169
    hy balerstraio i can help you with that task
    please share the dxf file, and i will handle it, including error deviation
    some verifications can be implemented, etc
    i create custom software, handling dxf geometry, math aproximation ( toolpath deviation ), etc
    if you wish, check attached video; i can also share a link, as soon as online backup will finish upload
    please, feel free to ask anything / kindly
  1. software to convert spline curve to tangent arcs
    By foxfx in forum Uncategorised CAD Discussion
    Last Post: 05-08-2014, 02:31 PM
  2. Convert spline to arcs or lines
    By mattpatt in forum Solidworks
    Last Post: 12-19-2012, 03:05 AM
  3. convert spline into equal length segments
    By maxidex in forum Uncategorised CAM Discussion
    Last Post: 08-20-2010, 10:20 PM
  4. Need help with Spline to DXF to Polyline
    By buscht in forum Autodesk
    Last Post: 07-29-2005, 03:43 PM
