588,444 active members*
5,316 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Autocad to gcode
Results 1 to 18 of 18
    Jun 2004
    14
    Autocad to gcode
    I've just started to learn how to use autocad and trying to convert drawings to gcode. I have to admit I really don't know what I'm doing. I can draw objects in autocad, but the only thing I can get gcode2000 to accept is 2d simple shapes. If I start putting holes or other items in it it comes out real strange. I have been unable to get it to accept and 3d drawing at all, it keeps telling me there is no usable information. I made sure to explode the drawing befor saving it to a dxf, but I still had no luck. I'll attach the autocad file I'm trying to convert using gcode 2000, maybe someone could give me a step by step walkthrough of the steps to get from a 3d drawn part to gcode. I would appreciate any help I can get.
    Thanks,
    James
    Attached Files Attached Files
    Feb 2004
    361
    not familiar with gcode2000, opened the file, used Kcam, got wierd reversal on 'part' of the drawing..
    Converted to dxf with autocad DXB utility, came out ok..
    with something simple like this, all you need is a 2d dxf, and input your Z depth directly into the nc code..
    not sure if this is the answer you're looking for,,but??
    enjoy..
    35538
    There are 2 free AutoCAD 2d gcode programs here that work right inside AutoCAD, My VBA G-code exporter and Bill's G-Code out lisp.
    If you want to do 3D stuff, I don't think gcode2000 supports 3D. You might want to look at MeshCAM. If you need help getting your 3D models into MeshCAM, let me know. It's easy if you use solid models, just export as .stl. If you use Meshes, you need to explode them into 3D faces and save as .dxf.
    Apr 2003
    1873
    James, here is a somewhat cleaned up and repositioned drawing and a NC gcode file for you too look at. As vladdy said your 2D drawing is all you need unless you just wanted to convert it to solids for rendering. It may be also that gcode2000 does not convert anything but 2D.
    Jun 2004
    14
    Thanks for the help,
    I've given up with gcode and tried kcam, I had the same weird reversal problem. Could it be the way I'm drawing the files. If i draw just 2d everything works fine. I also downloaded the trial version of onecnc and it loads the 3d file just fine. I don't have a cnc machine, not yet anyway, so everything I'm doing is just for learning purposes. I plan to build one in the near future. I want to be able to cut what I think is 2.5d. I guess I'm just trying to figure out how to get my 3d autocad drawing to gcode using any program necessary, but the cheaper the bettter.
    I've tried drawing the 3d objects use just squares and circles then using boundary and the extruding to the proper height.
    I've also tried drawing 3d boxes directly then drawing cylinders and using the 3d subtract function to cut out the holes in the solid. This seems to give the same weird results in kcam as the above, but works fine in onecnc.
    I've tried exploding everything before saving to dxf and that doesn't help either. I've only been using autocad for a couple of days, so maybe i'm just going about everything wrong.
    I can at least do the 2d drawings and get them to work in kcam, so I guess that is a start.
    I attached a photo of something i've been trying to get gcode for with only success using onecnc. I'ts just a square with filleted edges and a hole in the center.
    Jamey
    Jun 2004
    14
    ger21: I downloaded the trieal version of meshcam and tried using it with no success, it says it imports 0 faces. I did explode the drawing first. I'm not sure I did everything right. I attached the file I tried to open.
    James
    Nov 2003
    634
    James, I am not that familiar with the programs you are mentioning other than Autocad, but I don't think that you are doing anything wrong with your drawing.
    Its more of an understanding issue with the capabilities and quirks of the CAM software.
    For example, your drawing8.bmp could be considered 2-1/2D or 3D depending upon the capabilities of your CNC machine and/or how you choose to process the part.
    Some of the early CNC's could be programmed in X and Y, but only had a simple up/down command for the Z. Hence the 2-1/2 D. Along the way, this became the common way of describing flat parts with drilling or milling.
    Your part fits this category, with the exception of the chamfer. If you have a 45 degree router bit, then a 2D part path will work. But if you want to use a straight bit, then this becomes a full 3D part and the cut path becomes lots small steps to interpolate the angle.
    Not all CAM programs can take a 3D file, some work off the 2D geometry and you have to do a little creative manipulation to get the results you want, some CAM programs only use 3D files, MESHCAM for example. This program assumes that you are going to mill the entire piece to size, not simply cut the square, circle, and chamfer. Higher end programs can accept all types of CAD, but these have a long learning curve and costs $$$$$.
    I would recommend you do any tutorials that came with the software demos, learn what the program requires and then try and process your parts by drawing them in the way that the CAM program wants to see them.
    T
    35538
    Try these. You need to understand how AutoCAD works and how to use it with the CAM programs you're using. The hole in the middle can be done with 2D (2.5D), but the rounded edges probably need to be 3D. You can do the hole with MeshCam's waterline machining, but it's a new feature still being developed, and may be a little buggy.
    Jun 2004
    14
    ger21: Thanks for the sample file, it opened in mesh cam just fine. I'm also glad to see that meshcam is very afordable.
    I'm going to have to read a little more, I have no idea to get all the lines in there the way you did. I know there must be an efficient way of doing it. I'm going to have to just find some tutorials.
    Thanks,
    James
    35538
    Those aren't lines, they're edges of triangles. Select one and go to properties and it will tell you it's a 3D face. Here's how to get those. Under Draw>Solids, box and cylinder. Subtract the cylinder from the box. Use the "fillet" command to round the edges.
    Before exporting, type in "facetres" and make it 10 (it's 0.5 by default).
    For MeshCAM, use File>Export, and save as .stl. Stl's load faster than .dxf's. To get the .dxf, use File>Export, and save as .3ds file. Then use Insert>3D Studio, and load it back into AutoCAD, and save as .dxf. Always use V12 .dxf's, you'll have better luck with them.
    Apr 2003
    416
    James,
    I think best option for gcode from Autocad is Tahlcam. The demo is a free download, and will generate 1000 lines of gcode. Works inside Autocad. If you draw in solids you can use Modify-Solids Editing-Copy Edges to get the lines defining the path you want to machine. Tahlcam will convert the connected lines into a single path. It has a good hole routine. You can see your tool path on screen. Lots of other options.
    Bill
    Jun 2004
    14
    ger21:
    Thanks for all the help. I was able to export a drawing as a stl file and load into meshcam just fine. I was unable however able to import the 3ds file I exported back into autocad. I get the following error:
    Command: _3dsin
    Invalid file - 3D Studio file import terminatedCommand:
    The stl file works great though so I will just use that, but I would still like to know what I'm doing wrong with the 3ds file export/import.
    I tried to export the 3ds file just after I exported the stl. The stl worked fine like I stated above. When I click export, I get a bunch of options. I leave all as default and save the file. When I import I create a new file and try to import into there. I then get the error above. Am I missing something?
    I was also wondering is meshcam widely used in the cnc communitry. It seems like a great deal for the money.
    Thanks again,
    James
    Feb 2007
    15
    JamesMI,
    Meshcam is a great program for doing 3D machining on a tight budget. Its very powerful and easy to use. I haven't used it for 2D, its designed for 3D. Cost is about $250. For doing 2D I use vetrics Cut 2D and DXF from Autocad. SheetCAM is also ok for 2d stuff.
    For machining in Meshcam I always use a .STL file. AutoCad should export a 3D stl fine if your 3D model is made correctly. I doubt if it will import a .STL back as a 3D model into the software. I do not believe Solidwords or Inventor will either. Its a one way street. If you are changing or tweaking your 3D model you will have to create a new STL file after each change. Maybe I don't understand completely what you were trying to do.
    In short
    for 2D machining, Autocad created and exported DXF will work fine.
    for 2 1/2 D or 3D if using meshcam, a .STL is the way to go.
    35538
    Did you export the same model as .stl and .3ds? I can't see any reason why it doesn't work. I'm guessing your just not doing something correctly. I think you'll find that you really shouldn't need the .3ds option. Most CAM packages read .stl.
    As for MeshCAM, it was developed over the past year and Version 1 was just released about a month ago.If the majority of your parts will be flat with holes, then MeshCAM is not going to be you're best choice. You might want to look at SheetCAM. http://www.sheetcam.com It's free right now (under depelopment) A little tricky at first, but follow the tutorials and it gets easy fast.
    Jun 2011
    Hello, I'm new around here... I'm working on a project and I have to generate G-code for a CNC machine from Auto Cad, and I some help from some people with experience will really be helpful. I'm thinking of getting to generate the G-Code from lisp by having 2 drawings in Cad, in order to get the coordinates for a 3D dimension piece...
    Can anybody around hep me, thak you!
    35538
    bob-morey, you replied to a 7 year old question.
    Can anybody around hep me, thank you!
    How about this? AutoCAD 2 G-Code
    Sep 2011
    Same problems here
    I want to draw with Autocad (dxf) then convert them to G code
    My cnc software is Machmill Artsoft
    Please!!! help me out with that...
    Dont know how to convert it....
    Thanks in advance
    Aug 2008
    24
    Here is how i do 2d work with inventor
    Draw the 3d part, save
    Create a new drawing, import the 3d part and layout the part
    FRONT -- SIDE
    Save a Copy as DXF
    Import into Cut2D, Edit where needed..
    Fairly quick work tbh
  1. AutoCad 2000 DXF Question
    By Holmes_ca in forum Autodesk
    Last Post: 01-20-2005, 12:50 AM
  2. Edgecam with Autocad dwg for Lathe
    By wjbzone in forum Uncategorised CAM Discussion
    Last Post: 01-05-2005, 06:54 PM
  3. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  4. Autocad LT verse AutoCad LT
    By cncadmin in forum Autodesk
    Last Post: 02-03-2004, 02:28 PM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
