603,963 active members*
3,176 visitors online*
Results 1 to 5 of 5
Splint E-Stop triggers by itself... 01-16-2025, 03:52 PM
cncmakers001 Re: E-Stop triggers by itself... 01-16-2025, 04:05 PM
metalmayhem Re: E-Stop triggers by itself... 01-16-2025, 07:48 PM
Splint Re: E-Stop triggers by itself... 01-17-2025, 06:49 AM
Al_The_Man Re: E-Stop triggers by itself... 01-17-2025, 06:27 PM
    Jun 2003
    451
    E-Stop triggers by itself randomly
    Hi All,
    I'm getting back to using my router after a very long break and I notice that every once in a while, Mach 3 thinks the E-stop has been hit and it stops everything. It happens randomly and doesn't appear to be related to any movement in wiring or any other input. It's almost as if there's some sort of hardware or software glitch in the computer as everything can be stationary with the spindle off and it triggers. I haven't really had a chance to try and trouble shot it yet but I thought I'd ask here to see if anyone else has had any experiences like this.
    Splint
    Re: E-Stop triggers by itself randomly
    Quote Originally Posted by Splint View Post
    Hi All,
    Splint
    It could be the emergency stop button wiring problem.
    Or electrical noise from nearby devices or the spindle can cause false triggers.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    if it's noise then try setting the debounce interval to 50 to start , if that doesn't work then try 500 . This will delay the trip signal and should prevent noise from e stopping the machine . If it doesn't work then you have a lot of noise to weed out of the system
    I edited this from starting at 100
    I just looked at an old config of one of my mills which is factory built and I had it set to 50 . I'm sure I've had higher settings on some of my builds or retrofits
    Jun 2003
    451
    Thanks, I'll look into it,
    Dec 2003
    24260
    Experience from past posts on the subject usually turns out to be all PWR commons not grounded to the same star point in the panel.
    Albert E.
  1. False E-stop triggers. Need help finding and eliminating noise.
    By Jakeller449 in forum DIY CNC Router Table Machines
    Last Post: 12-13-2019, 03:36 PM
  2. Axis randomly stop working
    By groc426 in forum Mach Software (ArtSoft software)
    Last Post: 01-07-2018, 04:58 PM
  3. M03 Triggers E-Stop
    By fc60 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-13-2015, 12:50 AM
  4. steppers randomly stop as DRO still counts w/video
    By evermax in forum CNC Machine Related Electronics
    Last Post: 03-06-2011, 04:53 PM
  5. E-stop false triggers
    By Mooser in forum Xylotex
    Last Post: 12-16-2007, 04:52 PM
