603,323 active members*
3,144 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > KmotionCNC warning controller configuration takes longer to stop than 75%
Results 1 to 6 of 6
    Jun 2025
    3
    hello,
    inside homing machine routine, and when done zero(Z,X,Y) i'm trying to reset the toolchange position by sending MDI command as follow
    printf("Homing X,Y,Z is Done, Press OK to Reset ToolChanger\r\n");
    MsgBox("Homing X,Y,Z is Done, Press OK to Reset ToolChanger",MB_OK|MB_ICONEXCLAMATION);
    //MOVE Z UP 85mm for toolchange positioning
    MDI("G01 Z85 F3000"); //Z85=85MM
    during the execution and when i reach the MDI("G01 Z85 F3000"); //Z85=85mm
    i'm receiving a warning : controller configuration takes longer to stop than 75% of trajectory planner look ahead time.Feed Rate will be limited
    Limiting axis:Z
    Time to stop 8.18 sec
    lookahead 3.00sec
    i increased lookahead time to 10 and same result, check attached picture and codes
    May 2006
    4087
    Re: KmotionCNC warning controller configuration takes longer to stop than 75%
    The warning has to do with the manner that the Z axis Velocity, Acceleration, and Jerk parameters are configured which I don't being provided to us.
    A common mistake is to set an impossibly high velocity but not realize the velocity is unachievable, because a long enough move is never attempted to test it.
    This is like a having a car that you claim can go 1000mph with an acceleration of 10mph/second. This would take 100 seconds to accelerate to 1000mph, or 100 seconds to stop from 1000mph, but then you only ever drive in a parking lot.
    A similar situation can exist with Jerk.
    KFLOP/Kogna expects to have more than enough buffered motion to stop from a worst case situation without limiting any speeds. So it gives a warning.
    You would have to set the buffer time to 11 seconds (> 8.18/0.75) to avoid the warning. But you should not do this. Check your motion parameters instead. Most systems are capable of stopping in 1 second or less.
    HTH
    TK
    http://dynomotion.com
    Jun 2025
    3
    Thank you Dear Tom, the machine away now to try some changes, but this is the initializations of the old fanuc servos
    void Servo_Initialize()
    ch0->InputMode=ENCODER_MODE;
    ch0->OutputMode=DAC_SERVO_MODE;
    ch0->Vel=400000;
    ch0->Accel=100000;
    ch0->Jerk=1e+08;
    ch0->P=0.35;
    ch0->I=0;
    ch0->D=0;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=4000;
    ch0->MaxErr=4000;
    ch0->MaxOutput=4000;
    ch0->DeadBandGain=1;
    ch0->DeadBandRange=0;
    ch0->InputChan0=0;
    ch0->InputChan1=0;
    ch0->OutputChan0=0;
    ch0->OutputChan1=0;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchOptions=0x120;
    ch0->LimitSwitchNegBit=1028;
    ch0->LimitSwitchPosBit=1027;
    ch0->SoftLimitPos=1e+09;
    ch0->SoftLimitNeg=-1e+09;
    ch0->InputGain0=1;
    ch0->InputGain1=1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashMode=BACKLASH_LINEAR;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=1;
    ch0->Lead=0;
    ch0->MaxFollowingError=1000000000;
    ch0->StepperAmplitude=20;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    ch0->iir[2].B0=1;
    ch0->iir[2].B1=0;
    ch0->iir[2].B2=0;
    ch0->iir[2].A1=0;
    ch0->iir[2].A2=0;
    ch1->InputMode=ENCODER_MODE;
    ch1->OutputMode=DAC_SERVO_MODE;
    ch1->Vel=400000;
    ch1->Accel=100000;
    ch1->Jerk=1e+08;
    ch1->P=0.35;
    ch1->I=0;
    ch1->D=0;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=4000;
    ch1->MaxErr=4000;
    ch1->MaxOutput=4000;
    ch1->DeadBandGain=1;
    ch1->DeadBandRange=0;
    ch1->InputChan0=1;
    ch1->InputChan1=0;
    ch1->OutputChan0=1;
    ch1->OutputChan1=0;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchOptions=0x120;
    ch1->LimitSwitchNegBit=1030;
    ch1->LimitSwitchPosBit=1029;
    ch1->SoftLimitPos=1e+09;
    ch1->SoftLimitNeg=-1e+09;
    ch1->InputGain0=-1;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=-1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=1;
    ch1->BacklashMode=BACKLASH_LINEAR;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=1;
    ch1->Lead=0;
    ch1->MaxFollowingError=1000000000;
    ch1->StepperAmplitude=20;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    ch1->iir[2].B0=0.000769;
    ch1->iir[2].B1=0.001538;
    ch1->iir[2].B2=0.000769;
    ch1->iir[2].A1=1.92076;
    ch1->iir[2].A2=-0.923833;
    ch2->InputMode=ENCODER_MODE;
    ch2->OutputMode=DAC_SERVO_MODE;
    ch2->Vel=400000;
    ch2->Accel=50000;
    ch2->Jerk=1e+08;
    ch2->P=0.35;
    ch2->I=0;
    ch2->D=0;
    ch2->FFAccel=0;
    ch2->FFVel=0;
    ch2->MaxI=4000;
    ch2->MaxErr=4000;
    ch2->MaxOutput=4000;
    ch2->DeadBandGain=1;
    ch2->DeadBandRange=0;
    ch2->InputChan0=2;
    ch2->InputChan1=0;
    ch2->OutputChan0=2;
    ch2->OutputChan1=0;
    ch2->MasterAxis=-1;
    ch2->LimitSwitchOptions=0x120;
    ch2->LimitSwitchNegBit=1031;
    ch2->LimitSwitchPosBit=1032;
    ch2->SoftLimitPos=1e+09;
    ch2->SoftLimitNeg=-1e+09;
    ch2->InputGain0=-1;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=-1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashMode=BACKLASH_LINEAR;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=1;
    ch2->Lead=0;
    ch2->MaxFollowingError=1000000000;
    ch2->StepperAmplitude=20;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=0.000769;
    ch2->iir[2].B1=0.001538;
    ch2->iir[2].B2=0.000769;
    ch2->iir[2].A1=1.92076;
    ch2->iir[2].A2=-0.923833;
    ch3->InputMode=ENCODER_MODE;
    ch3->OutputMode=DAC_SERVO_MODE;
    ch3->Vel=400000;
    ch3->Accel=50000;
    ch3->Jerk=1e+08;
    ch3->P=0.35;
    ch3->I=0;
    ch3->D=0;
    ch3->FFAccel=0;
    ch3->FFVel=0;
    ch3->MaxI=4000;
    ch3->MaxErr=4000;
    ch3->MaxOutput=4000;
    ch3->DeadBandGain=1;
    ch3->DeadBandRange=0;
    ch3->InputChan0=3;
    ch3->InputChan1=0;
    ch3->OutputChan0=3;
    ch3->OutputChan1=0;
    ch3->MasterAxis=-1;
    ch3->LimitSwitchOptions=0x100;
    ch3->LimitSwitchNegBit=0;
    ch3->LimitSwitchPosBit=0;
    ch3->SoftLimitPos=1e+30;
    ch3->SoftLimitNeg=-1e+30;
    ch3->InputGain0=-1;
    ch3->InputGain1=1;
    ch3->InputOffset0=0;
    ch3->InputOffset1=0;
    ch3->OutputGain=-1;
    ch3->OutputOffset=0;
    ch3->SlaveGain=1;
    ch3->BacklashMode=BACKLASH_LINEAR;
    ch3->BacklashAmount=0;
    ch3->BacklashRate=0;
    ch3->invDistPerCycle=1;
    ch3->Lead=0;
    ch3->MaxFollowingError=1000000000;
    ch3->StepperAmplitude=20;
    ch3->iir[0].B0=1;
    ch3->iir[0].B1=0;
    ch3->iir[0].B2=0;
    ch3->iir[0].A1=0;
    ch3->iir[0].A2=0;
    ch3->iir[1].B0=1;
    ch3->iir[1].B1=0;
    ch3->iir[1].B2=0;
    ch3->iir[1].A1=0;
    ch3->iir[1].A2=0;
    ch3->iir[2].B0=0.000769;
    ch3->iir[2].B1=0.001538;
    ch3->iir[2].B2=0.000769;
    ch3->iir[2].A1=1.92076;
    ch3->iir[2].A2=-0.923833;
    EnableAxis(0);
    EnableAxis(1);
    EnableAxis(2);
    //EnableAxis(3);
    DefineCoordSystem(0,1,2,3);
    May 2006
    4087
    ch2->Vel=400000;
    ch2->Accel=50000;
    ch2->Jerk=1e+08;
    Here it would take 8 seconds to ramp up to a velocity of 400,000 count/sec at an acceleration of only 50,000 counts/sec? Can your system really go that fast? If so, does it really need to accelerate so slowly?
    TK
    Jun 2025
    3
    Thank you TOM,
    my question is,
    even if i limit the Feed rate to 3000, this will not help, and i'm using the DefaultKeepOffsetsMM.set units file in the KMOTIONCNC->toolsetup
    the KFLOP command execution following the KMOTIONCNC or no, so the unit F3000 is in inch? so i have to make it smaller or relatively so i divided by 1524 so F should be= 2, please clarify
    thanks
    Peter
    May 2006
    4087
    Hi Peter,
    The GCode or Feed rate doesn't matter. When the GCode starts executing it checks the worst case to stop from a rapid and that you are requesting sufficient buffering to handle that.
    Please answer the questions from my last post.
    TK
  1. Mitsubishi controller configuration
    By IgnacioQuijas in forum SERVICE FOR CNC-MACHINES
    Last Post: 03-24-2022, 03:05 PM
  2. Replies: 1
    Last Post: 06-30-2021, 09:39 PM
  3. Set up problems with Mach3 E-stop warning, Limit warnings etc.
    By skware in forum Australia, New Zealand Club House
    Last Post: 12-10-2014, 01:28 AM
  4. RS-232C Fanuc Controller to iLogic DNC configuration?
    By RC-CNC in forum DNC Problems and Solutions
    Last Post: 05-18-2009, 09:08 PM
