588,665 active members*
7,823 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 4 Axis Feedrate Calculation
Results 1 to 2 of 2
    Dec 2007
    I am using a GE Fanuc - 4 axis in a laser system (X,Y,Z,A). I have a matercam generated post that has extremely high feedrates on some tight corners. It is moving around the corner using the Y,Z, and A axis.
    Is there any way that I can calculate what the feedrate should be. I trust the mastercam but I have to make some changes at times and would like to know how to calculate the feedrate manually.
    Thanks in advance.
    Jul 2003
    1760
    I have no experience with anything over 3 axis. I hear though that inverse time feed is better in these situations.. where you tell it how long you want it to cut the line segment instead of how fast along the line you want to cut.
    (if that made sense..)
    (a bit over my head here)
  1. Back EMF calculation?
    By OCNC in forum Stepper Motors / Drives
    Last Post: 05-28-2014, 02:41 PM
  2. oz-calculation help needed
    By methuso in forum Stepper Motors / Drives
    Last Post: 09-25-2007, 03:39 PM
  3. Getting ready, need help calculation TCNC
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 07-22-2006, 11:23 PM
  4. Is this calculation correct?
    By h3ndrix in forum Stepper Motors / Drives
    Last Post: 02-07-2006, 07:08 AM
  5. resistor calculation need help
    By mike10 in forum Stepper Motors / Drives
    Last Post: 03-30-2005, 04:21 AM
