588,627 active members*
5,559 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Repeated cutting of 6AL4V Titanium - making small series - questions...?
Results 1 to 2 of 2
    May 2008
    48
    Question Repeated cutting of 6AL4V Titanium - making small series - questions...?
    Hello,
    this is my first post here... my name's Daniel, and I work as a bladesmith & machinist in switzerland, running my own small shop.
    (http://www.ferrumdg.com for those who want to know more.)
    When I make folding knives, one part of the job is to cut a 1,5mm (0.059") Ti-sheet (6AL4V - grade 5)... basically I need two identical pieces each time, one with some additional mods, but the outline is exactly the same.
    Now I'm working on a small series of ten identical folders, so I would need twenty Ti-liners cut out, identical to each other.
    I could send this off to a local laser or even better a water-jet cutting shop, and get it done that way.
    However for a long time now I was wondering if there's any "small-shop" way of doing this, with some speed and precision?
    I haven't sean any DIY WaterJet cutting tools or stuff like that.
    I've seen some DIY Wire EDM Setups, but have no idea what the capacity and precision of these are...
    Any ideas? machine plans? solutions.
    if I do single pieces, I use a band saw to cut the rough shape out, and then grind and mill it after having made a plastic prototype I use to transfer the outlines. it's simple and it works, but it's time consuming as well.
    Thanks,
    Daniel
    Jun 2003
    58
    How about a small cnc milling machine ?
    I use mine for cutting titanium blades, etc.
    Just been looking at your website - very nice work you're doing there.
    Rab
    CNC Toolkit
  1. cutting a taper on titanium rod
    By marty7001 in forum MetalWork Discussion
    Last Post: 05-21-2014, 02:06 AM
  2. Tapping very small holes on titanium
    By DIYist in forum MetalWork Discussion
    Last Post: 03-17-2009, 07:34 PM
  3. Making PCB's with a small cnc mill
    By DennisCNC in forum Community Club House
    Last Post: 12-21-2006, 11:51 AM
  4. Turning Small Titanium parts ??
    By BFcarbon in forum Employment Opportunity
    Last Post: 05-11-2006, 01:16 PM
  5. Titanium cutting? What to use!
    By Tazzer in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2003, 01:56 AM
