587,161 active members*
3,192 visitors online*
Thread: Whoops
Page 1 of 2 12
Results 1 to 20 of 44
    Jul 2005
    12177
    Whoops
    I guess after nine years of running CNCs I am allowed to have a serious crash, but I will try to avoid repeating it.
    Stopping a chuck spinning at 1000rpm by sticking a tool holder into the jaws tends to modify the toolchanger on a TL2.
    Feb 2004
    361
    ouch...
    and my old shop teacher used to tell me he'd smack me in the nuts with a rubber hammer if I accidentally left the chuck key in...
    So far I've been lucky, but he 'advised' me of the consequencews back in, oh, around 1970??
    at long as nobody got hurt,
    that's the main thing...
    Oct 2005
    672
    I bet you felt the "thunk" through the floor.
    That's why I'm chicken around lathes.
    15362
    Hi Geof
    Was this from programing or a machine malfuction this kind of crash makes cam software very inexpensive, That sure did a number. I guess Haas does no have soft limits that you
    can set for each tool so the tool can not get to the chuck, Did I see in one of your posts
    that you where from/or lived in NZ if so where in NZ we may have been doing the same thing there at the same time
    Mactec54
    Jul 2005
    12177
    It was an operator issue, coupled with the fact that I was doing a left hand thread.
    For the left hand I was starting at a Z minus location near the chuck and threading away. All my clearances checked out; when doing this the way I enter the Z offset is bring the tool to its closest location to the chuck, enter that as the Z offset then move the offset out by the distance the tool is going to travel. Perfectly safe!!
    But somehow I got the X value wrong so when the tool moved to the Z minus position the tip caught the part and the tool holder rotated in the turret. The back end of the holder kicked out just far enough to get caught by the jaws. That is why the turret is so mangled, the holder was sticking out about three inches like a pry bar.
    To answer your NZ query I lived near Auckland, place called Muriwai Beach. Left in 1966.
    15362
    Hi Geof
    Now I can see how it all got so mangled with it being able to turn when the tool hit, I no Muriwai Beach very well but was not living in Auckland untill 1967 & was more on the east coast & lived at Mairangi Bay I have a daughter that lives in Kumeu which is close to Muriwai Beach. I will be going to NZ on the 26 of May
    Mactec54
    Nov 2007
    1702
    WOW! Uhhh...lemme' get my thoughts straight. WOW!
    Nobody got hurt? Any other damage? That exact thing scares me too. Or the jaws being too far out of the chuck and hitting the cross-slide.
    Are you going to replace the changer or go for something like the Dorian turret?
    Greg
    Jul 2005
    12177
    Quote Originally Posted by Donkey Hotey View Post
    ... Any other damage?...
    That is a good question.
    The replacement turret is on its way by UPS Blue and will be here tomorrow; around $4500 including freight.
    I have a spindle bearing vibration analysis booked for next week to see if it is different to the one taken a few months ago as a baseline when I got the machine.
    I don't expect anything else to show damage mostly because the chuck slowed down 'gently' over about 1-1/2" of peripheral distance. Did you read my explanation above how the tool swung around and formed a long lever arm?
    Jul 2005
    181
    Man Geof... Why you've done that??? That's not funny to break down a machine, don't do that again okay?
    Feb 2007
    381
    That right there is the reason I cannot stand mounting the 3 jaw on our SL-10. I only do it if I absolutely have to. I like out 16C collet chuck. It's round. Probably the worst I could do is bump into it. But at least it wouldn't have a much leverage as a jaw stuck out 8 or 10 inches from the spindle center.
    Good luck Geof with the new turret. Just pray that it will be at least another 9 years before you crash one like that again!!
    Jun 2004
    84
    Quote Originally Posted by gizmo_454 View Post
    That is why I hide all the 3 jaw chucks that come on my machines & I forgot where I put them <G>. Only 5C & 16C collets, I don't do any work over 1 5/8".
    Now I do have engine lathes with big 3 jaw chucks for one or 2 parts.
    Jul 2005
    12177
    Quote Originally Posted by duenow View Post
    ....Now I do have engine lathes with big 3 jaw chucks for one or 2 parts.
    Years ago I had big turret lathes; Herbert #7's with 14" and 16" chucks. I stopped one of these once when a piece of parted off steel bar stock fell down between the chuck jaw and the saddle. What a bang; full stop within less than a degree of rotation from 1200 rpm. And nothing broke!!!
    Jul 2005
    12177
    The replacement turret was shipped as promised UPS Blue, arrived at my Haas dealer as expected two days later...and was promptly forwarded by some super zealous, but misguided person, to the wrong customer!!!!!
    Jun 2006
    47
    Geof,
    Do you know if the new style turret is available yet? If so is that the one you are getting? I heard it is suppose to be much faster and much more reliable but the last time I talked to Haas they were still working on it. My turret is starting to have problems again but I wont replace it until the new one is ready.
    Mark Hockett
    Apr 2007
    100
    I have had some good crashes and heard some others also. When no one gets hurt that is important. It makes me more careful setting up. When I am sure that when changing somrthing simple it is good then it can get me. I have been told I am slower setting up because I do not trust the program until proven. I am not a good programmer but wish to improve. I enjoy this site a lot and tell Geoff hang in there.
    Aug 2005
    578
    Yea Geof, think about doing that at 1430ipm.
    when I first got my Daewoo, I was running a little brass job, put and take job, had the door open and pushed the go button. Man oh man is this thing fast thinks I...
    Then I noticed the rapids were in 25%
    My new Horizontal rapids (And cuts) at close to 2000ipm.
    Mark
    The service guy just left. 9 hours to realign the thing. It took a hit...
    Bumped the wedges on the trucks. Put it all back together and it has less than a tenth across the turret, and the same in runout on the spindle.
    The roundy holders are about a half thou in Y
    I think that ought to work well....
    I am learning a lot about how to fix an sL10 though....
    Jul 2005
    12177
    [QUOTE=PBMW;455141]Yea Geof, think about doing that at 1430ipm...../QUOTE]
    But worrying about the rapids is not really logical, it is that many, many pounds of spinning mass that is going to do the damage whether you rapid into it or feed into it.
    But logic does not do away with the tight feeling in the gut sometimes.
    Aug 2005
    578
    [quote=Geof;455173]
    Quote Originally Posted by PBMW View Post
    Amen to that.....
    I used to program an Okuma crown fro a friend. He didn't know much about code. I'd rapid to about .02 off a face. Drove him nutz.....
    Jul 2005
    12177
    [quote=PBMW;455240]
    Quote Originally Posted by Geof View Post
    Amen to that.....
    SADIST.
    Jul 2005
    12177
    Well I finally received my replacement turret; a two day delivery that took ten days.
    And the box contains???? A full retrofit kit for a servo driven four position tool turret??? With instructions for the 'simple' installation involving new boards in the control cabinet, parameter changes, etc. My brain is too old for this, I will come back after getting hold of my local Haas rep to find out what gives.
    I think it would have been a much more better idea to have not crashed the machine in the first place.
    Why do I always think of the correct solution to my problems too late?
Page 1 of 2 12
  1. Whoops! Smoked all 4 channels?
    By Riceburner98 in forum Xylotex
    Last Post: 07-15-2007, 03:36 AM
  2. whoops accident. ignore this one!
    By vacpress in forum Linear and Rotary Motion
    Last Post: 03-12-2006, 09:47 PM
