588,616 active members*
4,634 visitors online*
    Jun 2006
    53
    servo conversion vs stepper conversion
    Can anyone give me a quick summary on what extra work is required to upgrade a bridgeport servo (interact mill) cnc to Mach versus a Boss stepper Mach upgrade. I have done a Boss 5 stepper conversion to Mach and would like to do the same with this interact machine. I would like to use Gecko drives and and keep this similar to my stepper machine.
    1121
    re
    I cannot see how steppers are an 'upgrade' in any way from servos. I think you would be much better off staying with servos, even if you have to pick a different conversion
    Jun 2006
    53
    That's fine, but can anyone tell me the difference in parts and labor required between a stepper and a servo conversion, using a Mack / Gecko style retrofit
    1121
    re
    Well, if it is a complete interact, it already has encoders servos and tachs. You may choose to replace the servo amps, because the amps are not as 'stiff' as newer ones. If you don't want to, I would just look for a replacement amp to keep on the shelf as a spare. What you need is a cnc that will output +- 10v rather than step direction
  1. X3 servo conversion questions
    By JB_in_Fla in forum Benchtop Machines
    Last Post: 04-18-2008, 06:06 PM
  2. Replies: 15
    Last Post: 05-19-2007, 10:12 PM
  3. RONG FU RF-31 Conversion Servo or Stepper
    By rpcaster in forum Knee Vertical Mills
    Last Post: 04-26-2007, 03:09 AM
  4. Stepper to Servo Conversion
    By runnoahrun in forum Servo Motors / Drives
    Last Post: 06-28-2005, 12:20 AM
  5. excello conversion stepper to servo
    By roonster71 in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2005, 02:15 PM
