588,208 active members*
4,896 visitors online*
Results 1 to 5 of 5
    Aug 2008
    573
    Z axis homing problem
    Hi all,
    I've just configured EMC2 for use with my homebrew engraver/mill. I'm really pleased with the way it went, pretty much hitch free (once I'd read the manual ). Much nicer than the TurboCNC I'd been using previously.
    The machine has only a small Z movement. I've configured the axis to home to a switch at +15mm.
    Most of the time, pressing 'home', winds the Z axis up to the switch then up/down before reseting the machine position display to 15.000 (exactly as expected). However after I've run an air cut, zeroed the axes with g00 x0 y0 z0, then press home all (or Z only) it'll home up to the switch jiggle (at about 15mm) then reset the display to 14.300.
    I don't think the Z axis is losing steps (and in any case the home should reset to 15.000 every time shouldn't it?)
    Any ideas?
    Oh and while have your attention; How do you get EMC to start full screen? (I'm a linux newbie)
    May 2005
    1662
    Quote Originally Posted by BillTodd View Post
    You would think think that would be simple, right? Not so. Search the linuxcnc.org wiki for the term devilspie . I considered that advice briefly and decided clicking maximize or hitting alt+F10 was less bother
    Can't think of the answer to the homing question. Maybe after some coffee.
    Interesting looking machine. If that's a homebrew you have some obvious fabricating skills. I love homebrews.
    Feb 2007
    514
    Bill if you are doing an offset and not resetting it after like in the MDI window EMC is correctly reporting your offset position after the home. Just do a G92.1 to clear the offsets and reset the variables to 0.
    http://www.linuxcnc.org/docview/html...,-G92.1,-G92.2,
    John
    Aug 2008
    573
    Quote Originally Posted by Big John T View Post
    John
    Thanks John.
    It wasn't actually offsets, but your post did remind me to check and edit the tool table. ops:
    I didn't realise EMC had a default set of tools, one being 0.7mm long!
    Aug 2008
    573
    Devils pie indeed
    It's bad enough that the computer world is filled with jargon, but when Linux developers use stupid names for applications etc. they shoot themselves squarely in the foot. It simply puts me (and many other people) off the idea of using the operating system
    Alt-F10 is is then :LOL:
    It's been in development for a decade. Most of it is parts recycled from other machines. I had only an old delta pillar drill when I started it, so I had to re-use any precision parts I could find (e.g. the lead-screw bearing blocks are cut from the end plates an 8" FDD drive motor).
  1. EZ-TRAK SX II homing problem HELP!
    By guitarist1904sd in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2008, 03:08 AM
  2. Just another homing problem
    By jeffrey001 in forum DIY CNC Router Table Machines
    Last Post: 06-01-2008, 01:18 AM
  3. Homing problem in mach2
    By atifeh in forum Machines running Mach Software
    Last Post: 12-20-2006, 02:25 AM
  4. Problem With Homing X Axis
    By elalto in forum Mach Software (ArtSoft software)
    Last Post: 09-16-2006, 01:28 AM
  5. Homing Problem V4.0.1
    By BMaynard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2006, 07:22 AM
