587,541 active members*
7,198 visitors online*
Results 1 to 5 of 5
    Oct 2008
    27
    Serieis 1 Interact 2 Heidenhain tnc 151
    Hi I'm newbie here and bought a used 1986 interact mill powers up clear power interrupted put in manual press and hold power enable and cycle start all axis move to reference and I can move y axis and Z axis but the x axis will not move in manual joy stick or hand wheel it will move + small amount and not - off limit switch gives a x- limits . like I said new to this machine and looking for some help .
    David
    Nov 2004
    3028
    You may have a bad parameter for the X travel limit.
    Do you have the parameter list?
    George
    Oct 2008
    27
    Yes I was reading the manual last night and found X limits setting paramter 44 45 will try this and see .
    Nov 2004
    3028
    Also check this. Press the MOD key, then use the arrows to scroll through the menu. One of those is user definable travel limits. That may be part of the problem.
    George
    Oct 2008
    27
    Hi Machintek thanks for the help i got machine making chips one more question I set paramter 225 to 12 to have a tool comp libary but it is in mm can i change this to inch the dro is in inch but the tool libary says mm is there a paramter to set this in inch.
  1. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  2. Heidenhain tnc 2500 on Interact 308
    By GarageShop in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2010, 11:57 PM
  3. Heidenhain TNC 2500 in Interact 308
    Last Post: 08-24-2008, 10:16 PM
  4. Bridgeport Interact 1 Mk2 Heidenhain error
    By joegille in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2008, 01:07 AM
  5. Interact 1 Mk2 with Heidenhain TNC155B
    By rrbmachining in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2007, 07:18 PM
