588,009 active members*
3,226 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Alarm 410 and 414 fanuc 18mc
Results 1 to 2 of 2
    Sep 2008
    22
    Good evening,
    friends I have the following problem when I move my vertical axis horizontal machining center, makes a noise as if hitting metal to metal, it is strange that sometimes leaves is not constant.
    Fanuc 18mc is a control, and the series of servomotor is A06B-0148-B177
    After the noise, see the "LOAD METER" on that axis is in more than 200%, the alarm goes 414
    Oct 2008
    106
    Sound like the ballscrew end bearing defective, you should remove the servo motor of the ballscrew and just run the motor only, if noise go away then possible the end bearing.
    Ahn Vuong
  1. Need file Fanuc 18Mc Nc-basic
    By Selimsalim in forum Fanuc
    Last Post: 10-08-2023, 09:50 AM
  2. Replies: 5
    Last Post: 12-16-2012, 08:43 AM
  3. Fanuc 18MC Question
    By swartling in forum Fanuc
    Last Post: 05-03-2011, 07:04 PM
  4. RISK 64 on Fanuc-18MC Controller
    By iNUC in forum Fanuc
    Last Post: 09-21-2008, 09:38 AM
  5. Large PartPrograms on Fanuc 18MC,how to
    By ddanutz in forum Fanuc
    Last Post: 10-30-2006, 07:05 PM
