587,375 active members*
3,309 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Switching from Mill to Lathe camv14
Results 1 to 3 of 3
    Jul 2009
    12
    Hello, I'm hoping someone can help me with this. I've been using Turbocadv14.2 along with the cam plugin v14. I have made several mill programs and today I wanted to build a lathe routine. Problem is, I couldn't get to the lathe tools. It seems that the first time you set it up is the only time you can choose a lathe or mill. I reinstalled the cam plug in and the first time I ran the wizard was the only time I can find the "General" choice which lets me define if this is a lathe or milling machine. Am I missing something? Is there some other place where I can choose if this is a milling operation or a lathe operation without having to reinstall the cam plugin?
    Thanks for the response, with a new drawing, you can change from mill to lathe or lathe to mill.
    Nov 2008
    31
    TURBO CAD
    SORRY ABOUT THAT TRYING TO BE TOO CLEVER AND CENTRE IT HERE IT IS http://wwwstugod.blogspot.com/ BEST REGARDS STU GOD
    Jul 2009
    12
    Link doesn't work.
  1. My CNC mill with mini lathe performing CNC lathe operations
    By ryansuperbee in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2008, 07:06 AM
  2. switching between 2 controllers ????
    By jubee in forum CNC Machine Related Electronics
    Last Post: 02-27-2008, 08:49 PM
  3. switching a 440v lathe to 220v
    By dannystooblue in forum Phase Converters
    Last Post: 01-28-2008, 07:24 PM
  4. Pwm switching
    By miro in forum Gecko Drives
    Last Post: 01-23-2007, 10:22 PM
  5. Switching to carbide?
    By warpedmephisto in forum Benchtop Machines
    Last Post: 06-23-2006, 10:46 PM
