588,156 active members*
5,042 visitors online*
Results 1 to 5 of 5
    Feb 2007
    107
    240 msb sub belts
    Why are my belts on my 240 msb (sub spindle) wearing so much.
    Ran fine for 2 years until the sub spindle belts needed to be replaced.
    Now they need to be replaced about every 6 months with a re-tighten once or twice in-between.
    The sub is used for very light duty work on brass, largest drill is 7/16.
    thanks,
    Bad Dog
    Nov 2004
    3028
    Are you using a cool blaster or such?
    I had 1 customer using a cool blaster and some bad coolant that made the belts soft. Office included a 2 year warranty to sell the machine. I believe they lost money on that one.
    George
    Feb 2007
    107
    sub belts
    I use a 3J dead length collet chuck and use the through spindle coolant all the time .
    I noticed last time when the serviceman pulled the covers off that the inside was pretty greasy. I wonder if over a period of time that's what is making the belts stretch.
    we use Hangstefers coolant at the moment.
    Bad Dog
    Other than the Belt issue machine runs almost 24 hrs a day and weekends no problem.
    Nov 2004
    3028
    This customer's sub spindle was wet inside due to the high pressure coolant fracturing to microscopic particles and getting inside the sub spindle housing. His coolant was attacking and softening the belts. Tightened them a couple of times, then replaced them. Tightened them again, then he sold the machine. In many cases the coolant evaporates leaving a residue that is gummy.
    George
    Feb 2007
    107
    sub belts
    thanks,,,,sounds like the same situation,,,,I think we will get in and clean out every 3 or 4 months. I understand the new ones have no belts and are directly coupled.
    Bad Dog
  1. V-belts
    By veteq in forum Mechanical Calculations/Engineering Design
    Last Post: 07-14-2009, 11:37 PM
  2. L Belts
    By BigBee in forum Want To Buy...Need help!
    Last Post: 03-18-2008, 05:43 PM
  3. Belvilles & V-belts
    By Shizzlemah in forum Fadal
    Last Post: 12-24-2006, 01:22 AM
  4. Belts & pulleys?
    By Splint in forum Australia, New Zealand Club House
    Last Post: 04-15-2005, 10:29 AM
  5. Timing Belts
    By chas in forum DIY CNC Router Table Machines
    Last Post: 01-19-2005, 04:03 PM
