588,495 active members*
4,209 visitors online*
Results 1 to 3 of 3
    Jan 2009
    57
    IMC Servo Motor specs
    Does anyone have the specs for this servo motor? Labeled IMC Universal Magnetics 4593313. Other numbers can be seen on the picture. Thank you for your help.
    May 2007
    119
    Probley from a plotter. i have two of them and have never found any usfull info on them
    Dec 2003
    24221
    For general calculations, the aproximate applied voltage can be found from feeding a DC voltage and measuring the rpm, if the max rpm is assumed to be 3000, then the max voltage to acheive this can be calculated.
    For other approximate figures, you could go to the CMC DC servo site and find a motor with the same dimensions, probably the 2500 or 3500 series, and arrive at an approximate torque value etc.
    There is also an encoder on the back, this should be possible to decipher the connections by examination, if the make is not shown.
    Al.
    Albert E.
  1. servo motor specs
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 03-04-2009, 07:34 AM
  2. SWI Prototrak Servo Motor Specs?
    By Bruce Griffing in forum Servo Motors / Drives
    Last Post: 02-19-2009, 07:03 PM
  3. SM-1 Servo motor specs
    By tjs88yj in forum HURCO
    Last Post: 03-26-2008, 04:06 PM
  4. Boss 8 Servo Motor Specs?
    By TurboStew in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2006, 05:46 PM
  5. servo motor specs and help
    By cowanrg in forum Servo Motors / Drives
    Last Post: 06-12-2005, 12:11 AM
