603,960 active members*
3,087 visitors online*
Results 1 to 3 of 3
mishikwest Reinstall control software 09-19-2009, 06:33 PM
joejared One at a time, go through... 09-20-2009, 04:42 AM
RandK Change your X/Y Orientation... 09-20-2009, 02:32 PM
    May 2005
    94
    LC 59120
    Hard drive in pc controller died, was running build 377. Fresh hard drive and windows install, upgraded to build 400. Now my axis orientation and distances are all wrong.
    If I tell it to go 1" in X, it moves like 1.75".
    edit: Found scale factor sticker on machine.
    How about this though still?
    Also my X+ and X- directions are swapped, and y+ and y- are swapped.
    Did I loose all sorts of other parameters when my hd died?
    Mar 2008
    91
    One at a time, go through your steps per unit If you have the high speed upgrade, it's different, but usually it's 20320 units per inch, -20320 if it's going the wrong direction. There's also a system setting for homing direction, but get your units right first. Then work on homing direction. Also, and because Techno's software is so buggy, quit the program after each setting change. One of the first things I'll be doing for one customer is removing Techno's software and installing my own, as it suits their needs better.
    Aug 2006
    133
    Change your X/Y Orientation to -1 in Setup>System. I'm still running 377 which you can still download. It has been very stable and functional. I'll try the latest version one of these days.
  1. How to reinstall Mazatrol T2 operation parameter?
    By Donatello Tam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2012, 08:10 PM
  2. Torq Cut 22 with DX-32 control: HELP me backup, format, install/reinstall, etc.
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2008, 08:45 PM
  3. Uninstall / Reinstall
    By j-radkemachine in forum BobCad-Cam
    Last Post: 06-05-2007, 04:13 PM
  4. BP Series 1 spindle speed / all out of whack... New Ajax dos reinstall...
    By peter.blais in forum Centroid CNC Control Products
    Last Post: 08-07-2006, 05:54 AM
