588,386 active members*
5,160 visitors online*
    Dec 2008
    8
    duel machines
    hello all, my first post. I run a plasma and a router off one computer and whenever changing machines i change the machine profile in deskcnc but also have to manualy change the post prosessor and options each time. I have tried loading two copies os deskcnc in two different directories but the config is defauled to c:documents and settings /deskcnc. both of my programs look for the last config used, regardless of being named differently. ie: deskcnc for router and deskcnc for plasma. the problem being that all machine configs are stored in one common directory and not seperate for each copy of the program. will partitioning the drive help, saving the two machines seperatly in c: and d: , or will deskcnc still put all configs in a common directory? sorry for the long post. appart from this minor problem I couldnt be happier with the function and simplicity of DESKCNC.
    Oct 2007
    269
    I also like DeskCNC. Could you setup each DeskCNC version on a separate PC? You would have to change the RS-232 cable, unless there is a switch for that. The keyboard, mouse, video can be switched with a KVM switch. PC's that are enough to run DeskCNC are inexpensive.
    Jim
    Oct 2007
    269
    BTW, welcome to CNC Zone!
    Dec 2008
    8
    thanks for welcome, 2nd computer is an option, however a simple "file" fix would be nice.
  1. REPLACE SYIL MACHINES WITH AMERICAN MADE MACHINES
    By heilcnc in forum Benchtop Machines
    Last Post: 08-24-2009, 07:53 AM
  2. duel controllers?
    By DerHammer in forum Mach Software (ArtSoft software)
    Last Post: 09-20-2007, 06:08 AM
  3. Duel V bearings and rails
    By grinder_gary in forum Linear and Rotary Motion
    Last Post: 01-13-2007, 12:56 AM
  4. Duel Rack and Pinion Drives
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 03-28-2006, 12:19 AM
  5. Duel Lead Screws
    By bb99 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 09:51 PM
