603,369 active members*
2,739 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > URGENT - Gould Gettys N360 Three Phase Half Wave Controller
Results 1 to 5 of 5
    Sep 2009
    3
    Dear Sir,
    We need to buy Gould Gettys - N360 Three Phase Half Wave Controller ( SCR )
    Type : A121
    Version : A121-39135-C-04
    240-300 VAC Line to Line 50/60 Hz
    Rated Motor Current : 33 A
    45A D.C. Continous Max.
    Qty --- 1 pc.
    Please advise the availability / Lead Time & price.
    If the above item is not available / or discontinued, please advise a suitable 1:1 replacement of the above.
    MATTER MOST URGENT
    Dec 2003
    24260
    You may have a problem getting an exact replacement as Getty's no longer exists.
    The options are repair to the existing one or sub a replacement from Baldor.
    Another is to retrofit with a AC spindle from Mitsubishi etc.
    The AC retrofit is often the same price as 3 phase DC replacement.
    Obviously the Baldor or Mits replacement requires some degree of knowledge capable of integrating the new unit.
    Al.
    Albert E.
    Sep 2009
    3
    Hi Al,
    Thanks a lot for your feedback.
    Can you advise a suitable part number / Type number of Baldor / Mits that can be used in place of this gettys unit?
    Best Regards
    EM
    Dec 2003
    24260
    I do not have specific part numbers for your application and the Baldor part numbers I have are dated.
    I would suggest contacting both Baldor and Mitsubishi for direct quote.
    The older info I have for Baldor is the BC20H series.
    The current Mitsubishi drives are SPA series with compatible motor supplied.
    You need to know the actual line to line voltage.
    The Mits will required both elecrical and mechanical changes, but if the motor is older or you anticipate motor problems down the road, the AC is the better way to go, especially if you are looking to keep the machine for some time.
    Al.
    Albert E.
    Feb 2010
    I have the item. Call me at 310-951-0105 or email me at [email protected]. I can respond in the evening Pacific time.
  1. Gettys Gould DC servo motor catalog
    By SHIVAMN in forum DNC Problems and Solutions
    Last Post: 07-24-2009, 09:11 AM
  2. Gould Gettys 410 Serial Coms
    By BMTS in forum DNC Problems and Solutions
    Last Post: 03-28-2009, 11:22 AM
  3. Sine wave for 5 phase 10 wire stepper (non-stared)
    By terrym in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2008, 10:57 AM
  4. Gettys N360 three phase half wave
    By bsharp in forum Servo Motors / Drives
    Last Post: 08-06-2007, 03:06 AM
  5. gould gettys servo motors
    By kollander in forum Servo Motors / Drives
    Last Post: 12-25-2006, 07:14 PM
