588,423 active members*
6,087 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > RFQ - Small production run of aluminum part - European Machine Shops Only Please
Results 1 to 3 of 3
    3
    Looking for a quote on a small production run of 100 of these. We need a few of them to begin with (less than 10) so that we can inspect the quality of the work, material, check tolerances, etc. and then if all is ok we will need immediately 100 more.
    Material can be 6063 or 7075. Whatever you have or can get the quickest. This project is time sensitive so I am looking for someone that can get them done as quickly as possible.
    Also, we do require that you sign an NDA & Non-Compete Agreement before we send any drawings to scale and with full measurements. We can supply IGES, para solid, and other formats if needed.
    Looking forward to hearing from you,
    JD
    Attached Files Attached Files
    6855
    Do you still need a Quote?
    3
    Quote Originally Posted by CNCadmin
    sure
  1. RFQ 4 parts(prototyping asnd small production run)
    By Bartman in forum Employment Opportunity
    Last Post: 07-27-2005, 07:24 PM
  2. Beginner moldmaking questions
    By fastturbovet in forum Moldmaking
    Last Post: 06-23-2005, 09:38 PM
  3. RFQ Small part
    By impact in forum Employment Opportunity
    Last Post: 02-14-2005, 09:05 PM
