588,611 active members*
7,187 visitors online*
Results 1 to 3 of 3
    Apr 2011
    69
    Smile FPC board laser cutting machine
    ◆ High-performance UV Laser Source: UV Laser is a diode pumped laser source with high beam quality, high peak
    power, short pulse duration and stable high power pulse, which is a "cold" process that ensures the stability of
    cutting quality.
    ◆ Optimized Optical System: This system ensures processing accuracy with lower power consumption, smaller spot
    size, higher beam quality, and supports autofocus function.
    ◆ Control System: High resolution linear gauge ensures the location
    accuracy and repeatability
    .◆ Natural Granite Platform: Natural and massive granite base reduces the inertia vibration of the table during start-up,
    shut-down and acceleration. At the same time, it maintains temperature stability.
    ◆ Air Bearing Design: Air bearings are used due to their high precision, long-term stability, frictionless motion and easy
    maintenance.
    ◆ Software: smart laser micromachining application platform, that is user-friendly, and supports most
    industrial data formats.
    ◆ Drilling and de-panelizing flexible printed circuit board, rigid printed circuit board, flexible-rigid printed circuit board, and
    chip substrate package.
    ◆ De-panelizing assembled flexible or rigid circuits.
    ◆ Precisely cutting and scribing ceramics with the thickness within 2.0mm.
    ◆ Precisely cutting thin copper foil, pressure sensitive adhesive, PP, acrylic sheet, polyimide film, etc.
    ◆ Precisely cutting ITO thin film, glass, organic thin film, special metal sheet, wafer and sapphire, etc.
    ◆ Support Roll to Roll Cutting way
    always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: [email protected] Skype:lisaseekcn
    Nov 2011
    can it drill the hole and cutting on FPC board
    we come from thailand, the fpc manufacture,we are looking for a machine which can drill the hold and cutting on FPC board, what is the quality guarantee. and cost ,delivery time?any details we can check .if there have video ?thanks
    Nov 2011
    thanks for your information,i link to your website of Hanzlasercn's Channel - YouTube ) for the machine operation.
    we will send you the details .
  1. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  2. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  3. Supply Laser cutting machine and Laser engraving machine
    By sherryguo in forum News Announcements
    Last Post: 11-27-2007, 02:47 PM
