588,017 active members*
8,592 visitors online*
Results 1 to 5 of 5
    Mar 2006
    7
    Chinese Mini Mill
    I picked a Chinese mini mill. But controller is shot. so i got a Gecko G540. I need help with the stepper motors.
    3 are Vexta DC 2.4 amp numbers on the lable are.
    103H7124-1142
    C299 581
    Z stepper motor is a Vexta
    3.1V 1.55amp
    C8513-9012K
    0441
    All are 4 wire.
    I called Vexta and they said those are com numbers.
    Any help on how I can tell whitch are the A and A- and B and B-?
    398
    Do you own a multi meter and can you measure resistance?
    Connect up one lead of the meter one wire. Find the other one that has a low resistance. That's one coil. Check that the other two they are the other coil.
    You now have identified the two coils. One is A the other is B.
    Now hook them up to the A and B terminal.
    Jog it. If the direction is wrong reverse one pair of coil wires. Direction should change.
    Take note of this on the other 2 motors.
    Repeat on the other small motor.
    Set current using resistor as noted in manual.
    Dave
    Mar 2006
    7
    THANKS!
    Thanks Dave!:wave:
    Mar 2006
    7
    Up Date my Chinese Mill
    I am adding a G540 to my Mill. I have a CNC4Pc C11-BoB. I need to add a touch and tool probe also a C16–photo limit & home board. Any though on this?
    Bob
    Sep 2007
    10
    How did the Gecko work out for you?
    I've got a machine with the same motors and seriously considering just getting the G540 and hope for smoother sailing!
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. best way to cut stock for machining on mini lathe/mini mill
    By crazybrit in forum Benchtop Machines
    Last Post: 12-31-2011, 10:40 AM
  3. Mini chinese laser problem
    By Machado3 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-08-2011, 12:06 AM
  4. Chinese Mill + Chinese accesory + Newbee = Problem
    By csaw in forum Benchtop Machines
    Last Post: 01-24-2010, 05:39 PM
  5. X2 Mini Mill & Mini Lathe - Cummins Tools
    By ccsparky in forum Benchtop Machines
    Last Post: 12-19-2007, 02:54 PM
