587,404 active members*
3,097 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > 3 ph spindle mtr on C6 lathe
Results 1 to 7 of 7
    Nov 2005
    34
    Has anyone done a 3 ph spindle motor conversion on the older (2005?) C6? I'm trying to get into the motor enough to read the plate without doing a total tear down, but it appears that the info on the motor plate does not conform to NEMA standards so I may have to remove the motor entirely to get the dimensions. Just thought someone else might already have that info.
    My objective is to go with a 3 ph motor and VFD to give me software control over spindle speed, or at least "turn of the knob" control.
    May 2005
    925
    It can be done, but you need to make a support plate for a standard motor.
    Have fun
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Feb 2012
    That is an overkill fot that size lathe,1ph is generous enough.
    What you have to think of is what the lowest speed will be,what is it by the way?
    May 2005
    925
    He didn't mention motor power, just that he wants to usa a 3ph (phase) motor and a VFD, from 0.75 to 1.5hp is enough IMHO
    Pablo
    Feb 2012
    My mistake maybe I should have put..."Single Phase"
    Feb 2012
    Yes,yours is not the ideal mounting way though.
    May 2005
    925
    Quote Originally Posted by HorridHenry View Post
    it works
  1. Lathe spindle speed and lathe facilities
    By GuntisK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2008, 11:22 PM
  2. looking to build 5c lathe spindle
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2008, 12:02 AM
  3. Lathe spindle bearings and spindle material
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2007, 08:49 PM
  4. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
  5. possible lathe spindle?
    By deferr in forum Vertical Mill, Lathe Project Log
    Last Post: 04-26-2007, 02:32 AM
