588,190 active members*
4,280 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > gildemeister ctx 400 series 2 cnc lathe with fanuc 21 it control
Results 1 to 5 of 5
    Sep 2013
    7
    In need of help asap m y turret on my gildemeister will not index it throws up an alarm saying not right position
    does any one know what the right counter number to set my turret
    Sep 2013
    7
    also what does it mean when the machine is in memory at the top of the screen has in red bc 0000000
    Aug 2011
    2517
    have not seen bc 00000000 on any 21i control
    normally the turret wont index unless you are at Y0
    what happened just before the alarm? normally this shouldn't happen all by itself.....
    Sep 2013
    7
    not sure what happened i was on vacation and came back to the problems. this gildemeister does not have a y axis only x and z it wont even run a program any suggestions ?
    Aug 2011
    2517
    you have not provided enough info. it sounds like you have a hardware problem
    try to zero return the turret. i.e. in manual mode index the turret.
    what is the exact alarm number and description?
  1. gildemeister nef 480 lathe- HELP !
    By dmelacom in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-01-2010, 06:41 PM
  2. Need help on Fanuc OI-td series control
    By khamul2000 in forum Controller & Computer Solutions
    Last Post: 07-20-2010, 11:13 PM
  3. Fanuc Series O-MD Control
    By dcskid in forum Fanuc
    Last Post: 03-26-2009, 12:22 PM
  4. X geometry in fanuc series O-TT control
    By cuz1007 in forum G-Code Programing
    Last Post: 03-15-2009, 12:40 AM
  5. CNC lathe Gildemeister NEF 480
    By pestana1957 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2008, 02:34 AM
