Originally Posted by
atmosports
We've got a Hit-15S & Hit-18S with 840c controllers. I've usually just used Hyundai's D-pro software to program/transfer but they stopped supporting the old software & the new software is fanuc only.These are the setting we use from Hyundai.
Device type = universal, protocol=rtc/cts, baud rate=9600, stop bits=1, parity=none, bits per character=8, X on character(Hex)=11, X off character(hex)=13, end transmission charcter(hex)=03, leader/trailer=no, ready=yes, stop at=m02/m03, end of block=CRLF, beginning output after Xon=No, Time in seconds=60, transmission format=Punch tape format.
protocol setting(Wincom)
port=com1, baud rate=9600, data bits=8, parity=none, stop bits=1, flow=RTS/CTS, terminal operation=autowrap, Use CN receive notifications & Display errors are on.
Hope this helps somewhat, there is a few other things you may also have to do if you have 110018 serial interface not initialized errors etc, but usually if you've got the above setting correct & the cable is correct it should transfer.
Transfer procedure for data to lathe.
press communication button, press Data I/O, press data input, use the arrow keys, arrow down to user, press enter, arrow down to local, press enter, arrow down to the directory/folder/file you want, press enter, press input start, then go to the pc & press ok there to start the transfer.
