Good day all,
I hope everyone is having a great day!
I would like to know if the following is possible:
Can you thermoform a part WITHOUT a vacuum pump by only using a top and bottom plate to form the desired shape (similiar to an injection moulding tool but without the injecting/ejection).
The material I would like to form is 4 mm thick ABS and the draw depth is approximately 50 mm. The finished part size is fairly large (1200 x 800 mm). The sheet would still be heated using normal vacuum forming methods.
Thanks for the assistance!
Daz
