###See second post for some more infos###
Could need some help/suggestions in trouble shooting:
Finished an engraving, and when I wanted to re-run the job, he Z-Axis started making a terrible noise and is slowly dropping. In the video linked bellow, you can see and hear what I'm talking about. The Z-Axis starts dropping slowly as soon as I hit "reset" on path pilot after powering on the mill.
Other things I noticed: One of the lights on the controller is red whereas the other two controller lights are green (see picture).
Path Pilot gives a Z-Axis limit switch warning (see picture). I disabled the "home switches" and it doesn't fix the issue.
I'm thinking it must be the controller or motor. Not sure why I get the Z-Axis limit switch warning (haven't really looked into it yet) Any ideas what the issue might be?
Also, can I just switch out controllers to find out if it is a motor problem or controller problem? I could use the controller for the x axis on the z axis...
Video:
https://www.youtube.com/watch?v=HWb7...ature=youtu.be
Attachment 399994
Attachment 399996
