587,083 active members*
2,675 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > DC SERVO ISSUES/hrdwre issue?
Results 1 to 2 of 2
    Oct 2019
    9
    Hi there;
    I am in process of upgrading my DIY mill with CNC4PC components. ( C76 board with the UC 300 Ethernet system) I also switched from MACH2 to UCCNC. The machine will jog, but only at 10%. Any higher jog percentage and the drives fault out!
    What am I missing? ( I think it is a power issue to the servo. My systems Gecko 320's are powered like this. The positive wire comes from a 57v dc relay and the negative comes off the negative terminal of a large capacitor ( 47000mf , if I remember correctly)
    Can I get adequate current to drive the motor appropriately in this manner? The machine never would run at G-Code rate with the old configuration. It didn't matter what the value was it would only run at about 1.5 IPM. It would, however, jog at 100% rate.
    Confused!!
    Any help appreciated.
    Clint
    Re: DC SERVO ISSUES/hrdwre issue?
    Can you provide more details about the power input? Maybe consider taping a voltmeter probe onto the inputs and then observing if there is a voltage drop as you gradually ramp the move rates.
    If you can't even provide more than 10% it's definitely concerning.
  1. DIY machine having issues...stepper motors the issue??
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 04-01-2021, 07:18 PM
  2. CL Step servo issues
    By bsjoelund in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-12-2016, 03:25 AM
  3. Replies: 1
    Last Post: 09-10-2014, 01:05 AM
  4. POSSIBLE SERVO AMPLIFIER ISSUES
    By BornToWin in forum Fanuc
    Last Post: 09-12-2013, 01:57 AM
  5. Spindle Servo Issues
    By Hellbringer in forum Benchtop Machines
    Last Post: 10-10-2012, 04:41 PM
