588,268 active members*
9,872 visitors online*
Results 1 to 6 of 6
    Dec 2019
    12
    Deckel Maho DMC 70V Problem
    Hello to everyone
    I have a problem with my dmc 70v machine.
    Error messages
    15 VSP: Klemmung Z-Achse aktiv
    5 VSP: Sicherheitsfunktion
    And if i open and close door i get another error
    85 SSP: Sicherheitsfunktion
    Also on servo drives i get b, F4 E7, F3 E7, F1 E7
    Thank you very much.
    Dec 2019
    12
    Re: Deckel Maho DMC 70V Problem
    Anyone?
    Jan 2013
    474
    15 VSP = clamping Z axis active.
    5 VSP = safety Function
    85 SSP safety Function
    Could be Z axis clamp fault.
    I think the safety function error are dual channel from NC and PLC.
    Check Z axis clamp first.
    Dec 2019
    12
    Exclamation Re: Deckel Maho DMC 70V Problem
    Yes Z axis clamp is active, but i think its active because of other errors (safety function).
    Today when i turned ON machine i get more errors, and i see that one of the drives are not working.
    Dec 2019
    12
    Hello,
    My MDS-A-V1-35 drive for Z was dead, i replaced it with second unit i have.
    But now i have 2 errors:
    does anyone have a clue what it could be? How can i check Z clamp?
    Thank you!
    Jan 2013
    474
    Quote Originally Posted by M1lan2000 View Post
    Hello,
    Thank you!
    Usually, when the drives enable, vertical (z) axis unclamp shortly after (or(z) axis motor brake releases). However, the control has to confirm the motor is under power and holding position.
    The clamps (switch?)/ brake circuit (relay?) could be faulty or the plc output keeping it clamped for safety reasons.
    This safety chain needs investigation.
