588,490 active members*
4,109 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need back up parameters for fanuc o-tc
Results 1 to 5 of 5
    May 2023
    hello friends .
    I'm electronics technical. maintenance electronics board and make modification and solution for old system. hardware and software. I have fanuc o-tc series control.i found some problems in hardware. 1st problem makes cut off for battery line. so it's lost parameters. My customer don't have back up to parameters just have the parameters manuals .
    trying input all parameters manuals but didn't work also The operator's panel didn't work and unable chiose edit or automatic mode because this mode touch key's in The operator's panel not select switch. so I'm need back up file to sending it with laader or dnc to control. after it's working we can edit different parameters.
    Fanuc series o-tc type -A02B-0098-B501
    My [email protected]
    Dec 2003
    24221
    Re: Need back up parameters for fanuc o-tc
    You either need to contact the OEM/MTB or find someone with the same machine, Fanuc 0TC means nothing, the parameters & ladder etc are unique to a make/ model of machine and are originally set up by whoever designed the M/C.
    Albert E.
    May 2023
    Thank you
    How can contact OEM|MTB?
    I'm read to 27c256 (oe1 and oe2)and saved this file .
    And when erase this eprom and on The control give me massage 1- load pmc \3-run\4-run without pmc .and when press 1 Wait The file form pc. And I insert the diagnostic parameters 300-to 400 .but The control need packup file form PC
    Dec 2003
    24221
    What is the make model of the machine?
    Find out if still in business, if this was done with a private retrofitter, then you may have to get it recommissioned.
    Albert E.
    Aug 2018
    44
    I think you are talking about something on thé one you don't have any knowledge....
    Quote Originally Posted by Tm289 View Post
    Thank you
  1. How do I get my parameters back?
    By Btaylor171 in forum Colchester Tornado lathes
    Last Post: 04-05-2022, 10:39 PM
  2. Fanuc 6T Back-up
    By mjsparks in forum Fanuc
    Last Post: 03-28-2022, 07:02 AM
  3. Replies: 0
    Last Post: 02-24-2021, 06:06 AM
  4. Parameters and plc back up for gildemeister fairchild 100 with 810d
    By TOM-CAT in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2016, 12:43 PM
  5. Replies: 0
    Last Post: 03-08-2013, 09:52 PM
