588,183 active members*
4,359 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > NEED HELP! - Fanuc Combo Drive Down Again (3rd time)
Results 1 to 3 of 3
    Sep 2018
    38
    Part Number in Question: A06B-6134-H303#A
    Sharp SV 2412
    Fanuc Oi Mate MC
    I've had the combination drive repaired 2 times prior to this for the same problem.
    I turned this machine back on yesterday after not using it for about a year. It looks like the 449 alarm is back again (this time on the Y Axis). The back of the combo drive shows "9."
    I managed to get it powered up once without an alarm, home the X and Z axis, but when I tried to home the Y axis the alarm came back (438 Abnormal current, combo drive shows "C").
    Any theories why this keeps happening? This machine barely gets used. I Megged all 3 axis motors + harness and they're all over 1000M?. Supply voltage is good (217v no big variance between phases).
    Thanks,
    Max
    Mar 2024
    37
    Re: NEED HELP! - Fanuc Combo Drive Down Again (3rd time)
    ok, Let me check reason of it. please discuss your problem with me at [email protected]
    Apr 2024
    3
    Are you sure that the axis is running free?
    If the motor needs too much torque/current, the IPM module can also trigger the alarm.
    Otherwise I would try to replace the amplifier with a good one for testing
  1. Replies: 9
    Last Post: 04-14-2023, 05:55 PM
  2. 3rd generation breakout board and MA860H drive controller
    By waterrat in forum DIY CNC Router Table Machines
    Last Post: 01-17-2015, 06:48 PM
  3. Drive support combo
    By country kid in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-16-2012, 10:05 PM
  4. At boot time press a combo of keys
    By Bill Johns in forum Fanuc
    Last Post: 12-08-2009, 01:43 AM
  5. 3rd CNC ROUTER BUILD time to get serious.
    By Oldmanandhistoy in forum CNC Wood Router Project Log
    Last Post: 02-22-2006, 11:41 PM
