588,268 active members*
9,622 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam 3000 Error: "Warning Low Voltage (4.89VDC 0.00 VAC)
Results 1 to 3 of 3
    We are using a Multicam 3000 with a Colombo spindle and also a knife tool holder. When rebooting the machine from router to knife or vice versa the following error message appears on the handheld controller:
    Warning: Low Voltage (4.89 VDC 0.00 VAC)
    Cancel makes the message go away and there is no other sign of trouble. Machine works as usual.
    Does anyone know what that means or what to do about it?
    Aug 2006
    Where are you located? your getting that because your 5v power supply is out of range it may just need to be adjusted or it may need to be replaced. chances are if its dropping voltage then it will need to be replaced some time soon.
    I am located in Edmond, OK. I replaced the connector on the cable to the hand held control and since then the error did not appear again. I guess the operator stumbled across the cable more than once and ruined the connector.
    Just in case it does, how do I adjust the 5V, what needs to be replaced?
  1. Multicam 3000 low airpressure error, please help
    By lukaspanic in forum Commercial CNC Wood Routers
    Last Post: 04-12-2008, 01:29 AM
  2. Multicam 3000 Unloads Tool Holder
    By wkranzjr in forum Commercial CNC Wood Routers
    Last Post: 03-15-2008, 01:34 AM
  3. X2 error - "warning - profile is not correct"
    By kprice1658 in forum Mastercam
    Last Post: 09-14-2007, 01:32 AM
  4. Multicam 3000 Nightmare
    By angelocmp in forum Waterjet General Topics
    Last Post: 08-30-2007, 02:32 AM
  5. MultiCam 3000 error message
    By DRolph in forum Commercial CNC Wood Routers
    Last Post: 01-11-2007, 10:30 PM
