588,069 active members*
4,753 visitors online*
Results 1 to 7 of 7
    Mar 2011
    cant cut with versalaser 25 watt vl200 samples?
    I can engrave using coreldrawx5.
    However i tried drawing a box with a redline to cut through a .25" piece of wood. and all it did was engrave it very lightly.
    My laser is used, I'm not sure if a lens is bad, or what my issue is.
    To see if its operator error with corel draw I was wondering if someone could send me a sample file for VLS or coreldraw and a picture of how it turned out on your laser, just so i can see if the machine is working properly.
    Jul 2008
    776
    What is your red line thickness? Schould be hairline.
    How it looks during cutting? Laser move according line drawing for cutting?
    And what is your settings for engraving and cutting?
    Oct 2010
    Is it going right to left over and over again drawing the box like an inkjet printer, or does the laser head move in a square motion then stop?
    Jul 2008
    776
    pantallica - you have put here few questions, cnczone members trying help you and it's look not good when you just ignore your own topics :stickpoke
    Mar 2011
    sorry for the lack of response one mirror had a crack in it. Replaced the the mirrors and now we are good to go.
    It doesnt always cut all the way through but thats just going to take trial and error on different types and thicknesses. Thanks for the responses.
    My red was also a wrong shade so i changed my color pallete.
    As far as motion it moves left to right. I am confused though because sometimes it cuts out the shape then engraves inside it. other times it will engrave the inside part first then cut out around it. They were seperate projects so I don't know what I did differently.
    Oct 2010
    Did your laser come with any other software to use besides Corel draw? What is happening is it's being sent to the laser and it's telling it what to do first, you can set the order of when it cuts and when it rasters separately, I don't know how to do this in Corel. Does it use another program like lasercut, or newlydraw?
    Oct 2004
    158
    Using object manager in Corel, you can specify the order by having the first item at the bottom of the list, and the last at the top.
    Bob
  1. For Sale - HPDFO upgrade for VersaLaser VL200
    By jalles in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2011, 02:05 PM
  2. Used VersaLaser VL200 - 30 watt for sale
    Last Post: 01-18-2011, 12:30 PM
  3. Lightly used VersaLaser VLS2.3 w/ 30 watt for sale
    By jason w lynch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2010, 09:55 AM
  4. ULS vl200, m-300
    By [email protected] in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2007, 09:21 PM
  5. Tutorials , exercices, samples , mold samples
    By engrsc in forum Solidworks
    Last Post: 02-22-2007, 04:24 PM
