587,372 active members*
3,371 visitors online*
Thread:
Results 1 to 20 of 266
Threaded View
    35538
    After 4 years of design changes, and a few prototype parts, construction is under way on Z², a mostly wooden machine with ultra high performance goals.
    For anyone who hasn't seen the design thread, it's here.
    Cutting are will be ~50"x72"x6". Both spindles will have full access to the cutting area.
    All NEW Hiwin linear bearings.
    15" 15mm rails with flanged blocks on the Z axis.
    67" 20mm rails with flanged blocks on the Y axis.
    These have already been purchased.
    X axis will be ±90" rails, either 20mm or 25mm.
    Z axis' will be driven by G251's powering 380oz steppers and 1/2-8 4 start screws from Roton, with modified Roton plastic nuts.
    This may be upgraded to G201x's and the new 400 oz motors from Gecko.
    X and Y axis will be driven with my stepper powered version of Mike Everman's Servobelt
    I built a prototype, but the final versions will be modified slightly for more strength.
    Gecko G201x's powering 570oz motors, geared 4:1. X axis is dual driven with slaved motors.
    Per my usual pace, this will likely take another 2 years to finish.
    Here are a few AutoCAD renderings to get started.
    Attached Thumbnails Attached Thumbnails Render 1.jpg   Render 2.jpg   Render 3.jpg
