I am using Velocity 3. My issue is When i construct different views and post the 4th axis values are inverse of what they should be. I did a test with a 4th axis trim cut and that works fine. the A values are correct. They are only backwards when i use views. Is there any way to solve this on m-post? Has any body had this issue before?
I have attached the post that I am using.
Any help would be appreciated.
cheers
Marcus
