Originally Posted by
Mountaincraft
I'm actually considering 3 possible methods, and one of them involved making two shafts with two cams on each with a screw to adjust the rotation of the shafts to lift the table up or down.. Rollers would be mounted to the underside of the table for the cams to push against...
The idea for leveling on that system would be to mount each end of the four shafts through threaded heim rod ends which could be adjusted up/down using nuts on their threads through a mounting plate..
The other method is to use four ACME screws and a bicycle chain underneath.. A smaller dive sprocket would be used for gear reduction, and on the opposite side a spring tensioned idler gear... and yes, set screw mounting of the gears on the screws for leveling of the system..
The reason I'm starting to lean this way is because with the cam method I'd have to install four 1/2" guide bars to lock x/y lateral movement of the table anyways.. and that means drilling the holes and installing shafts right where the screws would go anyways..
The other method I was considering was using a scissor lift type of mechanism, but I'm having a hard time figuring out how I would do 'leveling' of the table with that system...
