Need some opinions and guidance on this, is it good for a duel driven gantry and a turning station?
Looks to be an easy hookup.
Thank you for your input,
Craig
5 AXIS (TB6560) CNC STEP MOTOR DRIVER [CNC5AIXS55] - $149.99 : CNC Driver ARM Ulink 5-axis BDM Keil Mill - CNCGeeker.com Univelop Tech. LLC, CNC
5 AXIS CNC STEP MOTOR DRIVER 's features:
HUGE improvements from TA8435 based boards **
Resolution: Full step, 1/2, 1/8,1/16 selectable via switch for each axis.
Absolute maximum ratings: 40VDC @ 3.5 amps(peak)/phase motor output per axis *
PC parallel port DB25 connector has being installed onboard.
Adjustable motor current at 100%, 75%, 50%, 20% of full current by on-board switch
Supports different 4 Wire, 6 Wire and 8 Wire stepper motors for 3 axis drive.
Built-in overheat protection circuit in TB6560
This board is tested through KCAM, Mach 2/3, touborCNC CNC software.
This board has been used in different design 3D engrave machines, millers, routers.
Double Buffer for Interface and Driver for reliable Driving and protecting Computer and driver board.
1KV, 10 Mbps high speed Optocoupler for full elimination to protect Computer and driver board.
Step Current(r) Technology included: Step Current technology is used to decrease the current upto 1/2, when motors are in idle for all axis so as to protect expensive step motor and driver board for long time running.
* See TB6560 Datasheet by TOSHIBA. The full current is preset at 2.5A by resisters for this board (you can adjust it by changing them).
**Comparison between TA7835 (used in Univelop V1.0 CNC driver) and TB6560 (used in V2.0 CNC driver board):
