Looking for a little help to point me in the right direction. I have been accumulating parts for and building my own CNC machine over that last 15 months or so. The last part to install was the spindle and VFD. I picked up the 2.2 kw VFD and spindle from a US distributor. After getting the units installed and properly wired, I started up the VFD with factory defaults. When I hit the run button the spindle starts to spin up but faults at a frequency of about 14 on the display with a dl code. Checking the code it says there has been a short in the power leads to the spindle. I've checked and re-checked the cable from the VFD to the spindle and there are no shorts. The cable is 18 ga shielded cable with the shield connected between the spindle plug and the VFD earth ground. If I hit stop then start again the error is repeatable. Not being an engineer, I'm not sure where to go from here. Anyone have some ideas I can try to resolve this issue?
